-   -   What sealant is used on the floor pan plugs? (http://www.jeepforum.com/forum/f12/what-sealant-used-floor-pan-plugs-1530864/)
UZI4U 06-01-2013 08:14 AM
I cleaned up some rust the PO didn't get before bedlining the inside of the tub. I had to take out the 2 3/4" plug in the drivers side pan and it had some super sealant holding it in. Anyone know what the stuff is? I would rather use that than something like RTV or silicone because the bed liner won't adhere to those. JB weld would be a last resort.
PA_YJ19 06-01-2013 09:35 AM
It's known as seam sealer, go down to ur local autobody or paint supply store and ask for it. Doubt ull find it at a parts store, other option is to order it online. 3m makes a good seam sealer...
schaef89 06-01-2013 09:39 AM
I got seam dealer at AdvanceAuto
UZI4U 06-01-2013 12:02 PM
I found some at Ace, of all places. Thanks!
SuperMidget 06-01-2013 10:09 PM
i've pulled all the plugs out of the wife's jeep... makes it easier to clean up when i take the water hose to the inside
102joe 06-02-2013 08:34 AM
I leave mine out too , although it sucks when you forget they're out and and the river is a lot higher than you remember :rolleyes: = wet feet
UZI4U 06-02-2013 10:23 AM
I
m considering that as well There's no increase in noise and I don't have any carpeting. I might fab some inserts for the winter to keep out the snow and slush.
Cobra21 06-02-2013 02:58 PM
I got some plastic ones. I forget where I got them but they have teeth so when you tap them in they stay there. Really easy to put in.
gsnfl 06-02-2013 09:12 PM
Rubber expansion plugs from tractor supply. They have all the sizes in the floor and just need a wrench to tighten them up. About a buck a piece if I remember right
UZI4U 06-03-2013 08:37 AM
If you can recall, let me know.
boujo 06-03-2013 10:00 AM
Ebay, get some plastic ones. They are even black to match the bedliner
superj 06-03-2013 11:13 AM
yup, thats what i have
Luuca 06-03-2013 11:25 AM
I'm not 100% sure these little drain plugs are what you are after, but I used these from quadratec on our YJ.
http://www.quadratec.com/products/55005_51.htm
they stay in without sealer. I think you need 11 for the entire pan.
UZI4U 06-05-2013 08:36 AM
Thanks, but those aren't what I'm after. The factory has 2 3/4" holes right in the center of the floor pans on each side. They have a metal plug and are glued in there with sealant. I'm getting some samples from a few manufacturers to see if they will work. Nobody seems to have 2 3/4" though.
Firefyter-Emt 06-05-2013 08:58 AM
95 Attachment(s)
You do want a normal auto body seam sealer. Get a 1-quart can and an acid brush to brush it around the plug.
The time now is 12:33 PM.
