what's the point? - JeepForum.com
post #1 of 5 Old 12-11-2001, 03:43 PM Thread Starter
byj92
what's the point?
body lift??? i just don't get it....why?
byj92 is offline
post #2 of 5 Old 12-11-2001, 04:04 PM
OhYeah
Better approach/departing angles, room for bigger tires and more room to flex, less body to get hung up on rocks, stumps, trees, etc. Those are 4 good reasons. Here are a couple of other conveniences as well: Easier to clean the undercarriage with pressure hose, easier to work on your jeep, that is if you have the 3".
Are you thinking of doing one or just trying to be funny?
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #3 of 5 Old 12-11-2001, 04:16 PM
OhYeah
Originally posted by :
I agree with you, but having the body farther off the ground alone is a benefit on the trail even with a stock suspension. If you drive the trail right and keep your wheels on top of the big stuff you are cool. But if your bumpers are too low, it can be more difficult to get your wheels up on that stuff. Plus when you come over a big rock, alot of time you will come down on your rocker panels and if your rocker panel is higher then the frame, you can come down on the frame which means, less body damage.
But, you are always better off with a suspension lift over the BL because the SL actually increases your overall ground clearance.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #4 of 5 Old 12-11-2001, 04:17 PM
OhYeah
Why did big 92 delete his post? Oh well!
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #5 of 5 Old 12-11-2001, 04:44 PM
dennisuello
dennisuello's Avatar
body lift on it's own doesn't give you better approach/departure angles. the frame is not moving anywhere, so the bumpers, suspension components stay where they are too.
dennisuello is offline
What's really the point? ToothpickJ TJ Wrangler Technical Forum 16 01-21-2011 11:24 PM
What's the point? triplej1954 YJ Wrangler Technical Forum 29 02-11-2010 10:14 PM
5-point in a TJ mpyusko TJ Wrangler Technical Forum 35 12-18-2007 04:06 PM
At What Point............... LowCash TJ Wrangler Technical Forum 1 11-24-2006 09:12 AM
Tow Point.... mudbugII YJ Wrangler Technical Forum 11 12-19-2005 05:58 PM
