What's the name of this part? - JeepForum.com
post #1 of 7 Old 03-26-2013, 03:06 PM Thread Starter
DarthBrooks
What is the name of the five pieces with the rod bearings that are visible? The rebuild kit that I ordered only came with one. Are not all of them necessary?
DarthBrooks is offline
post #2 of 7 Old 03-26-2013, 03:08 PM Thread Starter
DarthBrooks
I only have the short one that's directly in front of the middle pile of synchros. Also, what are those small pieces next to the tube?
post #3 of 7 Old 03-26-2013, 04:50 PM
rogerv
The small pieces are called synchro blocks, the bearings are called cage bearings. Did you get a master rebuild kit or a shortened version?
Look on YouTube under ax-15 rebuild. Will Robinson has a series on rebuilding one. Mean max also has a write up in the forum on rebuilding.
If it's not broke- modify it, so it won't break
rogerv is offline
post #4 of 7 Old 03-27-2013, 12:55 PM Thread Starter
DarthBrooks
It would seem I got the shortened one. I've read Mean Max's thread and it will be very helpful. But are new cage bearings necessary if the old ones work? I guess what I'm trying to say is should I replace them anyway since I have the thing already taken apart?
post #5 of 7 Old 03-27-2013, 01:13 PM
rogerv
If you have the new parts and it's already apart- yes put them in. Have you checked your tolerances yet with feeler gauges ?
rogerv is offline
post #6 of 7 Old 03-27-2013, 01:23 PM Thread Starter
DarthBrooks
No. Please expand?
post #7 of 7 Old 03-27-2013, 01:56 PM
rogerv
PM sent
rogerv is offline
