What's in my Axle? - JeepForum.com
post #1 of 18 Old 05-21-2013, 11:10 PM Thread Starter
ign_cas
What's in my Axle?
Hey guys. Bought my YJ around 3 months ago. Just changed the gear oil in my Dana 44 and came across this. Im not sure if it's a locker? TrueTrac? Or maybe I'm just trippin and it's just an open diff. I couldn't really find anything that would tell me. Any idea? Thanks guys.
ign_cas is offline
post #2 of 18 Old 05-21-2013, 11:27 PM
fbv193
Limited slip, looks like a powerlock. (Not a locker)
fbv193 is offline
post #3 of 18 Old 05-22-2013, 08:23 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Can't really see inside. Spin the wheel a little and lets have a look in the hole.
Luck Favours The Prepared
Anticanman is offline
post #4 of 18 Old 09-12-2013, 01:39 AM Thread Starter
ign_cas
Sorry for the LONG delay. I finally got the time to open up the diffs again. The first 2 pictures are from the rear (44) and the last 3 are from the front (30). Do you guys have any idea? Is the front open? Rear locked? Thanks guys.
ign_cas is offline
post #5 of 18 Old 09-12-2013, 03:41 AM
timatoe
timatoe's Avatar
I see spider gears not a locker.
timatoe is offline
post #6 of 18 Old 09-12-2013, 04:56 AM
SeanB95YJ
yep... it's a standard open diff
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #7 of 18 Old 09-12-2013, 06:04 AM
bogleparsons
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #8 of 18 Old 09-12-2013, 10:21 AM Thread Starter
ign_cas
For front and rear axle?
ign_cas is offline
post #9 of 18 Old 09-12-2013, 10:24 AM
bogleparsons
none of the pictures you posted indicate anything other than standard spider gears in an open differential housing.
On a positive note your gears look to be in good shape!
post #10 of 18 Old 09-12-2013, 10:42 PM
jagular7
You can see how the open diff works. The pinion spins the ring gear. Ring gear is attached to the carrier or case. Inside the case, are 2 pairs of gears, axle and spider. The long center rod is the center pin that holds the spider gears. As the case/carrier spins, the rod rotates the spiders. As the spiders rotate, they spin the axle gears. The axle gears are splined to the shafts. When open, the application spins both axle gears same amount, ie like a locker. But when there is more restriction on one side to the other, all movement flows to the less restrictive axle.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline
post #11 of 18 Old 09-13-2013, 09:48 AM
NHfireLJ
NHfireLJ's Avatar
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #12 of 18 Old 09-13-2013, 04:28 PM
jason m
Nothing but the facts
jason m's Avatar
The rear looks to be a LSD.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #13 of 18 Old 09-13-2013, 04:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Jason.
Like they said: open, open.
post #14 of 18 Old 09-13-2013, 11:09 PM
jason m
jason m's Avatar
I understand the pun of your joke but to answer the OP's question the rear is a LSD, you can tell buy the carrier.
Click to View Search Results for Google (Search Results) Google (Search Results)
You can tell buy the square notch cut carrier, But yes in the offroad world pretty much a open diff.
Jason.
jason m is offline
post #15 of 18 Old 09-14-2013, 09:32 AM
PA_YJ19
X2, def a trackloc or LSD rear 44. The opening in the carrier is square, dead give away. The opening in the carrier would b round if it was an open differential.
Also I think anti was just joking, because LSD sux offroad.
PA_YJ19 is offline
