What's a good suspension lift for a '95 YJ? - JeepForum.com
post #1 of 29 Old 11-26-2001, 02:24 PM Thread Starter
bobznew
Hello all! I'm new to the Jeep world; just purchased a '95 YJ. I'm looking to put a suspension lift on it, about 3-4" probably. I was wandering if anyone could give me the names of some good suspension lifts that I might look into getting. Thanx much, and good wheelin'.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #2 of 29 Old 11-26-2001, 08:04 PM
osburn
osburn's Avatar
You can't lose with the RE Extreme Duty 4.5" lift.
Matt Osburn
Score 1032
osburn is offline
post #3 of 29 Old 11-26-2001, 08:05 PM
Newfie
Superlift, ProComp, Old Man Emu, Rubicon Express, BDS... The list goes on and on...
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
post #4 of 29 Old 11-26-2001, 08:26 PM
CR Perry
After looking at all the available YJ lifts I determined that the Rubicon Express 4.5" Extreme Duty was the most bang for the buck without going SOA. I'm very happy with it.
95 Wrangler
Rubicon Express 4.5" Lift
CR Perry is offline
post #5 of 29 Old 11-26-2001, 10:56 PM
jeffy
jeffy's Avatar
Pro Comp good?!? That's got to be one of the worst liked lifts for YJ's. I'd go RE or else piece together your own "kit" with some custom made leafs and other odds and ends. Requires more work on your part though. RE's extreme Duty is a good choice though. Don't get the standard duty since it's just a Pro-Comp and rides just as hard.
*** www.4BangerJP.com ***
jeffy is offline
post #6 of 29 Old 11-27-2001, 03:01 AM
runovru
I've driven several yj's with different kits on them and Currie has the best springs currently availabe. Use in conjunction with the Pro Comp Box Kit, pitman arm, and good shocks such as rancho 9000s, edelbrock, or bilstein 5100s, and you've probably got the best riding kit out there at 4". Plus if you want to bigger and badder later they have add-a-leaves available that provide an additional 1" lift while only stiffening the spring rate apx 15%.
runovru is offline
post #7 of 29 Old 11-27-2001, 05:22 AM
Jeep Chic
Any kind of lift over 2.5" and you may run into having to do an SYE.(slip yoke eliminator) and that can get very costly. I went with the BDS lift and a shackle lift and am very happy with it. I got a total of 4" of lift with this combo, and all I had to do was drop the Transfer Case an inch, the BDS comes with the drop kit too. I have seen way to many Jeeps with more than a mild lift break drive shafts because of not doing the SYE and the drive angle was just too extreme. If you want to do it right, call the # I posted on your other post and they will be more than happy to help you out.
Jeep Chic is offline
post #8 of 29 Old 11-27-2001, 05:42 AM
Newfie
Know several guys with 4Lts & winches, running ProComp 4" lifts and they are quite happy with it now that they have opened up the packs a little. They have not had issues with sagging like a lot of other lifts I've seen either...
Newfie is offline
post #9 of 29 Old 11-27-2001, 07:21 AM
Atropine
Atropine's Avatar
Im happy with my Rough Country lift. It rides smooth, little bouncing and it was $389 with everything (transfer case drop, brake line extensions, pitman arm)
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #10 of 29 Old 11-27-2001, 01:19 PM
bonehead99
bonehead99's Avatar
I installed a Rough Country 3" lift a few months ago and I love it!! The only thing the kit is missing is new bolts for the springs. My bolts were stuck in the metal sleeves and had to be torched out. For the price its a really good deal.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #11 of 29 Old 11-27-2001, 02:23 PM
osburn
osburn's Avatar
I agree Newfie. When I was running production kits, Procomp was the only spring that would hold my heavy Jeep up.
Matt Osburn
Score 1032
osburn is offline
post #12 of 29 Old 11-28-2001, 03:58 PM
Brendan
quote
"Pro Comp good?!? That's got to be one of the worst liked lifts for YJ's. I'd go RE"
I heard that the regular RE lifts use ProComp springs, and all the rest are RE components. It might have been just a rumor. I heard it when I started asking around about the 2.5" RE lift.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #13 of 29 Old 11-29-2001, 07:04 PM
geepYJ95
Originally posted by Jeep Chic:
Any kind of lift over 2.5" and you may run into having to do an SYE.(slip yoke eliminator) .
what is a "slip yoke eliminator"? and did anyone have this problem?
Green Jeep Club Member #14
'95 YJ Sahara Edition, green w/ tan hard and soft tops, Flowmaster 40 series, New cat, 2 10"eclipse subs, pioneer cd deck, and Xtant A series 6001 amp.
geepYJ95 is offline
post #14 of 29 Old 11-29-2001, 08:13 PM
osburn
osburn's Avatar
It moves the slip in your rear driveshaft from the tcase, to the driveshaft. If you look under your Jeep at your rear driveshaft, you'll see it can slide in and out of your tcase. Not an ideal setup.
But ignore the comment you quoted. On any lift 4" and below you can drop the tcase.
Matt Osburn
Score 1032
osburn is offline
post #15 of 29 Old 11-29-2001, 09:53 PM
jeeping18
last winter i installed the pro comp 2.5 inch lift on my 91 yj and it was very complete and pretty easy ( only problem was the rusted bolts ) the lift is good but extremly rough on the road and stiff off-road, shackles and disconects are recomended.
1991 YJ
-4.0L I6
- BORLA CAT BACK EXAUST
-2.5 INCH PRO-COMP LIFT
-31X10.50 PRO-COMP MUD'S
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
jeeping18 is offline
what's a good suspension lift to get??? wildride89 YJ Wrangler Technical Forum 30 08-16-2009 09:19 AM
Cheap but good FULL suspension lift to fit 33's wmeyer116 TJ Wrangler Technical Forum 17 02-20-2009 10:56 AM
I need a good suspension lift????? Divebum TJ Wrangler Technical Forum 6 12-13-2008 12:25 PM
Anyone got a good price $ on a bds 2'' suspension lift bigjeep310 YJ Wrangler Technical Forum 9 09-08-2004 10:34 AM
rancho 2 1/2 suspension lift any good? Nine5YJ YJ Wrangler Technical Forum 6 03-03-2004 06:32 PM
