what's the easiest way to tell if your front axle is still locked up? - JeepForum.com
post #1 of 4 Old 01-21-2002, 07:25 PM Thread Starter
iamthemellowman
I plan on jacking up one tire with the engine off and transfer case shifter in 4wd(after making sure there is no reserve vacuum).. and seeing if i'm able to freely rotate the tire. I imagine there might be an easier alternative.. if so any help would be a great help.
oh and if it is stuck, what are the steps to unstick it?
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #2 of 4 Old 01-21-2002, 08:17 PM
RodeoRob
RodeoRob's Avatar
Get rid of it... those things are prone to failure. Replace it with a Posi-lok or defeat it all together by installing 1-piece shafts.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 4 Old 01-22-2002, 09:21 PM
YJ boy
Well mellow you can go the post I put up on 01-20-2002 and see how to fix your problem the topic is "Vacuum lines" by YJBOY good luck. but if you really want to check it with out jacking it up you can pull your rear drive shaft off and try it then ??
YJ boy is offline
post #4 of 4 Old 01-24-2002, 06:41 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
On YJ's the easiest way to see if the front diff is locked in is to grab the drive shaft and attempt to rotate it in any direction. If it spins, its not locked up.
Make sure that your rig is properly parked when you do this. If the front of your rig is in the air, the drivers side tire might spin with the driveshaft if its locked in.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
easiest axle swap for 35+ tires emahan01 YJ Wrangler Technical Forum 15 05-13-2009 06:19 PM
04 Rubicon front locked flashing, front locked x50plt TJ Wrangler Technical Forum 7 02-20-2009 10:24 AM
My front axle wont stay locked in. UGH!!! Please Help! metal_kid17 YJ Wrangler Technical Forum 12 04-09-2008 07:32 PM
Easiest replacement rear axle 01amberfirewv YJ Wrangler Technical Forum 2 09-04-2006 09:03 PM
Front axle locked? nightstalker5.0 YJ Wrangler Technical Forum 12 01-18-2005 07:17 PM
