What's this connector (and bonus OBA question)? - JeepForum.com
post #1 of 5 Old 01-14-2014, 06:55 PM Thread Starter
YJ475
So, I've got the air conditioning pump all hooked up physically, and the system is plumbed. I've hot-wired it and filled up a tire, and now it's time to wire the dash. I pulled the dash cover off, and figured I'd mount the switch next to the rear wiper switch. When I got the covers off, I saw a red connector that looks just like the black connector for the rear wiper.
Then I had an evil-genius type thought: what if this is where the original wire ends up for AC? I know where that is, since I re-used the connector to hook up my AC pump. If that were the case, I could use that original wire in my circuit, and not make a mess of the wiring in the engine bay.
So, here are the questions I have: Is this red connector the AC connector? If so, how would I figure out which terminals to use in the switch, and would finding a junkyard stock switch work?
YJ475 is offline
post #2 of 5 Old 01-14-2014, 07:32 PM
Old4X
1990 CJ7
I thought that was for the rear window defogger
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 5 Old 01-14-2014, 08:49 PM Thread Starter
YJ475
Dang. That makes sense, since the Rock Auto catalog shows the rear defogger switch being the same size/shape. Guess I'll be running a new wire...
YJ475 is offline
post #4 of 5 Old 01-21-2014, 07:39 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The red plug is for the rear defroster. The black plug is for the rear wipe/washer.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 5 Old 01-21-2014, 08:50 PM Thread Starter
YJ475
I ended up just pulling a new wire in through the firewall. It's all wired up now. Thanks.
YJ475 is offline
