What's the best brand of grease to use with greasable bushings? - JeepForum.com
post #1 of 15 Old 08-17-2009, 09:16 PM Thread Starter
southbound
Quick question- the title pretty much sums this up, but what's the best brand of grease to use with greasable poly bushings? I'm installing my OME suspension kit this weekend and want to do this right the first time.
Also, along with your recommendations, please give the retailer that stocks the grease (preferably somewhere that would carry it locally, not an online retailer)
Thanks ,
southbound is offline
post #2 of 15 Old 08-17-2009, 09:24 PM
johnroot01
i use white lightning lithium grease. its available at auto zone, advance auto parts, and i think i've even seen it at wally world.
95 YJ: 4" RC, 1" booms, 1" BL, 33x13.50x15 SS TSLs, 15" RCX steelies, minus sway and trac bars
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
johnroot01 is offline
post #3 of 15 Old 08-17-2009, 09:27 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I use Sta-Lube Marine Grease.
You should be able to pick it up locally, pretty easy.
Joe Dillard is offline
post #4 of 15 Old 08-17-2009, 09:36 PM
plowboy87
EP for ME.
molly comes in to play some times too
not too sure where to find them down there but i bet and auto parts store should have them
plowboy87 is offline
post #5 of 15 Old 08-17-2009, 10:25 PM
idaholtby
I used Energy Release G-100 lithium. Google it, great stuff.
idaholtby is offline
post #6 of 15 Old 08-17-2009, 10:47 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Simple answer: Have you ever heard of bushings failing because of the "kind" of grease used? No. They fail or wear out because of "lack" of grease. Just pick the brand you want and lube regularly.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #7 of 15 Old 08-18-2009, 01:51 AM
MAILEBOY
What kind of bushings do you have? If it's poly bushings i've searched poly bushing grease and found that poly bushings don't like petroleum base grease, they suggest synthetic grease, available at most parts stores, i used it on my greasables with poly bushings, but like the rest of the guys said, main thing it's greased....just thought i'd mention the poly & synthetic grease....
MAILEBOY is offline
post #8 of 15 Old 08-18-2009, 09:05 PM Thread Starter
southbound
Obviously I've never heard of bushings failing because of the brand of grease used... And yes, I assumed any brand of grease would probably work... (I work with heavy machinery every day and am familiar with these things) But I just like knowing what other Jeep owners use and recommend. Isn't that the purpose of this forum?
post #9 of 15 Old 08-18-2009, 09:18 PM Thread Starter
southbound
Maileboy, thanks for the poly/synthetic recommendation; I'll have to look into that.
post #10 of 15 Old 08-20-2009, 07:37 PM Thread Starter
southbound
So I picked up some Green Grease brand synthetic grease from Autozone. This stuff looks like it will do the trick. Thanks for the help guys,
post #11 of 15 Old 10-24-2011, 02:04 PM
Morgen251
2010 JK Wrangler
Not a bad question as some lithium greases (PB is one that comes to mind) even though they say Silicone Lithium grease are actually petroleum based which can cause bushings to break down early. Non petroleum based (silicone) is the way to go.
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder.
BUILD:
Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines
WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery
Morgen251 is offline
post #12 of 15 Old 10-24-2011, 02:09 PM
94chb
i use marine grease since i trail ride alot of water.
94chb is offline
post #13 of 15 Old 10-24-2011, 02:21 PM
92 Green YJ
92 Green YJ's Avatar
What Joe said. I tend to stick with marine grade grease on everything in and under the Heep. It just seems to hold up a it better As its designed to not break down when it gets wet
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #14 of 15 Old 10-24-2011, 02:22 PM
jbolty
jbolty's Avatar
Hopefully the OP has found time in the last 2 years to grease his bushings.
I got a tube of heavy equipment grease at napa. I don't recall the brand but it was supposed to collect less dirt; I'm guessing it is less stick on the outside after a while.
jbolty is offline
post #15 of 15 Old 10-24-2011, 02:44 PM
Louie4
I use regular chassis grease. Mainly because I have a couple cans leftover from other jobs and no matter what grease I use it still tends to get dried up and full of dirt. But that's just me.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Need greasable shackle bolts and bushings Shags78 YJ Wrangler Technical Forum 7 11-24-2008 02:06 PM
Buying greasable bushings, should I replace stock shackles? CaptAmerica219 YJ Wrangler Technical Forum 12 01-09-2008 05:21 PM
Grease for Polyurethane Bushings goatboy YJ Wrangler Technical Forum 3 08-28-2007 03:30 PM
Steering Grease Bushings gallowspole76 TJ Wrangler Technical Forum 1 05-21-2007 12:38 PM
what grease for main eye bushings? 91GTA350 YJ Wrangler Technical Forum 1 11-09-2005 10:27 PM
