What's the BEST 4" suspension lift - JeepForum.com
post #1 of 7 Old 01-23-2002, 04:10 PM Thread Starter
BIG KEV
I've got an 95 yj with an I-6, and I am looking for a 4" lift? I want 33x12.50 tires. I'm looking hard at Procomp and BDS lifts. Somebody give me some advise to which ones the best or tell me about your experiences. Any other 4" inch lift advise welcome.
Punisher 95 YJ
SOA 103' WB 40" IROKS
Kingpin HP60 / 60 5.13's locked
KORE4x4CUSTOMS.com
BIG KEV is offline
post #2 of 7 Old 01-23-2002, 04:37 PM
Trucidus Sum
0000000000000000000000
Trucidus Sum is offline
post #3 of 7 Old 01-23-2002, 05:53 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I also am running SkyJacker lift of 4" .. very stiff with stock axles, but I can fit 33 by 12.50 MT's on it.
My plan includes (and hopefully before summer starts) full-width axles in SOA with 36" to 38" tire. I think this setup should help soften my ride considerably.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 7 Old 01-23-2002, 07:57 PM
Renagade1213
NAEKID, we are about it the same boat. How do u plan on goin to 38s and making a better ride? let me know thanks
91 YJ renagade 4inch procomp lift, 2 inch body, 35x12.50 goodyear mt/r
Renagade1213 is offline
post #5 of 7 Old 01-23-2002, 09:06 PM
rivertrout10
rivertrout10's Avatar
Big Kev - suggest you take a hard look at Rubicon Express's extreme duty lift kit. It is a totally complete kit and I am sure you wont be disappointed. I have seen many brands of lift kits - and most will sag an inch or so after a year. I have had this lift for a over a year and a half with no noticeable sagging. It is a 4.5 inch lift and looks good with 33's which is what I run as well.
Good luck,
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #6 of 7 Old 01-24-2002, 06:33 PM
NaeKid
NaeKid's Avatar
Hey Renagade1213,
I am hoping to complete the change over with no body lift as well .. but to make the long story as short as possible ...
  • 4" heavy duty SkyJacker lift
  • 3" - 5" (approx.)SOA Chevy axles, slightly modified
  • Bushwacker cutout fender flares
  • Tiny body lift to fit the new engine if required
By my estimates, if I can currently run 33" tires with 4" of lift comfortably, (quick math equation 33" tires - original 29" tires = 4" difference) and gaining 3 to 5 inches in height plus the fender flares (capable of opening the wheelwells to allow for 33" on factory springs) would get me really close to the 38" tire size.
I already helped a friend do this exact modification on his '87 YJ, and with sagged out 2.5" lift springs, 3" body and the SOA Chevy axles he has more than enough room for 38.5" tires (currently running 35" Baja Claws which look tiny with all that spare space!).
Silver
NaeKid is offline
post #7 of 7 Old 01-24-2002, 09:31 PM
YJNotDone
I just installed the Pro Comp 4" lift on my 95YJ a couple of months ago. I am running 33x12.50 tires and have decent clearance. I have read a lot of bad things about Pro Comp, but I love mine. It rides better than stock on my Jeep. It's also warrantied for as long as it is installed on the vehicle so if they sag they can be replaced.
95, 4" susp. lift, 33x12.50 ProComp M/T's, custom square tube bumpers, , energy bushings, 4.0 HO, everything stock, 1" or 2" body lift and who knows what else coming soon.
YJNotDone is offline
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
98 tj wrangler (4" suspension lift + 3" body lift) jeepster069 TJ Wrangler Technical Forum 5 05-03-2009 04:28 PM
Very newbie question on "side affects" of YJ Suspension lift... YJfromTJ YJ Wrangler Technical Forum 9 07-26-2006 10:07 AM
1" or 2" Spring Spacer with 4" Suspension Lift on 2000 TJ iBkickinit TJ Wrangler Technical Forum 12 03-20-2006 08:25 AM
