What part do I need? - JeepForum.com
post #1 of 15 Old 08-08-2013, 04:19 PM Thread Starter
chuck172
What parts should I get to fill in this gap?
chuck172 is offline
post #2 of 15 Old 08-08-2013, 04:29 PM
GrantYJ
There really isn't one. You've got an aftermarket flare (the part around the wheel). The factory flare went back and met the side moulding. Typical YJ's didn't have the step/side moulding (just a little end piece on the tub that terminated it), so when you removed the flare and take off the little end piece, an aftermarket flare (like the one you have) looks fine.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #3 of 15 Old 08-08-2013, 07:03 PM
sprngrider
Its overkill but lose the steps and get some rock sliders. Or get two stock tj flare extensions and cut them so they fit.
1994 2.5L WRANGLER S.
sprngrider is offline
post #4 of 15 Old 08-08-2013, 07:12 PM
bpounds
bpounds's Avatar
Get rid of the silly looking flares.
JMHO
bpounds is offline
post #5 of 15 Old 08-08-2013, 08:28 PM
jokerchief462
Put on some rock sliders. Remove everything between the wheel wells.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 15 Old 08-09-2013, 03:18 AM Thread Starter
chuck172
I might be getting a pair of 6" bushwacker flare extensions. Would they work with the rugged ridge flares I have on now?
chuck172 is offline
post #7 of 15 Old 08-09-2013, 05:33 AM
Rproject
1987 YJ Wrangler
They might, but they won't tie in cleanly to the factory step.
Another option would be to put in tube steps, or if you can enter/exit without the aid of a step, just ditch the existing step and be done with it.
Oh, BTW, watch those Rugged Ridge fender flares, they're not the most durable in the world. They have a tendency to crack in cold weather. Especially by the mounting bolts.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 15 Old 08-09-2013, 06:17 AM
UZI4U
I'd take them off and deposit them in the nearest trash can. Steps and running boards are for old folks.
MCLMM
UZI4U is offline
post #9 of 15 Old 08-09-2013, 06:50 AM Thread Starter
chuck172
I'm 60!
chuck172 is offline
post #10 of 15 Old 08-09-2013, 07:41 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You could find a pair of stock extension endcaps and install them on the opposite side so that they finish the running board and not the front fender flare.
Or you can adios the steps altogether and get somethig different.
Luck Favours The Prepared
Anticanman is offline
post #11 of 15 Old 08-09-2013, 08:42 AM
JrTjK
1978 FSJ Wagoneer
that was going to be my suggestion...you might have to trim the stock ends down but they should work.
search google for part # 55007316 & 55007317
JrTjK is offline
post #12 of 15 Old 08-09-2013, 08:56 AM Thread Starter
chuck172
[QUOTE=Anticanman;15774438]You could find a pair of stock extension endcaps and install them on the opposite side so that they finish the running board and not the front fender flare.
That's a good idea, not very expensive either
chuck172 is offline
post #13 of 15 Old 08-09-2013, 09:29 AM
GrantYJ
That's a very clever solution...
GrantYJ is offline
post #14 of 15 Old 08-09-2013, 09:50 AM Thread Starter
chuck172
I ordered part # 55007316 & 55007317. Came out to less than $20.00 including shipping. Thanks everyone.
chuck172 is offline
post #15 of 15 Old 08-09-2013, 10:21 AM
jeep108
When i put on my tj flares I actually cut part of the front flare and to fill the gap. I Tried being all fancy using a miter saw and then quickly realized it was easier to use scissors!
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
