What is this part? - JeepForum.com
post #1 of 12 Old 10-18-2007, 02:17 PM Thread Starter
EJames1226
EJames1226's Avatar
What is this part?
What is this part called that i highlighted? What does it do? Where does it go? Do i need it? Is it expensive?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #2 of 12 Old 10-18-2007, 02:24 PM
bobbert350
bobbert350's Avatar
umm my guess is heater control vac or something like it...i would keep it if its broke you can get a new one i think the people at HELP have them and usually available at most parts stores
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #3 of 12 Old 10-18-2007, 02:36 PM Thread Starter
EJames1226
EJames1226's Avatar
Heater Control Vac? As in the heater that i can control inside the jeep? My heater still works i think.
post #4 of 12 Old 10-18-2007, 02:41 PM
muddy93
1987 FSJ Wagoneer
prety sure that is a vacume check valve.
shoud be fairly cheap too.
muddy93 is offline
post #5 of 12 Old 10-18-2007, 06:42 PM
lutzke21
I think that line runs down to your front axle disconnect...
A small fire took mine out... replaced it so that I could get 4WD again...
So do you need it? Only you can answer that question. Got Posi Lock? Then no...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #6 of 12 Old 10-18-2007, 06:55 PM
will_982
It is the vaccum control valve for the auto hubs, all those lines go back to the transfer case. I think the other line right next to that just ends a couple inches lower than that valve.
will_982 is offline
post #7 of 12 Old 10-18-2007, 07:18 PM
jbars
what's this
while we're playing "what is it", right below the part you highlighted, in the lower center of the picture is what appears to be a small rubber hose sticking straight up with what looks like a wooden dowel stuck in the end of it. Does anyone know what that is and what function it serves. I've wondered about that for a long time..
jbars
94 yj
hoosierland
jbars is offline
post #8 of 12 Old 10-18-2007, 07:24 PM
will_982
air valve for the transmission, there is one up front next to the rad for the front axle
will_982 is offline
post #9 of 12 Old 10-18-2007, 07:40 PM
lutzke21
Also known as a breather...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #10 of 12 Old 10-19-2007, 01:52 AM Thread Starter
EJames1226
EJames1226's Avatar
For the record, one of the tubes from this vacume thing runs to the fuel area, like on the intake manifold.
post #11 of 12 Old 10-19-2007, 06:13 AM
The Rat
It's probably a vac line from the Tcase then, if it has another line coming off of it near the intake going into the firewall, then that's what it is (that part that comes off would be going to the indicator light).
OH WAIT. WHAT?
The Rat is offline
post #12 of 12 Old 10-19-2007, 11:24 AM
zeus87gn
1987 YJ Wrangler
Ok, if you haven't figured it out yet, here's how it works.
In your picture you have circled the main vacuum check valve on the tube harness for the front axle disconnect. It serves the purpose of keeping the vacum in the engine when you don't have the TC engaged. The hose that runs back over to the intake manifold gives it the needed vacuum to operate the disconnect as the manifold is always in vacuum when the engine is running.
Get it?
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
Name that part! tedder19 TJ Wrangler Technical Forum 6 09-24-2009 04:52 PM
Mucket Seal part number question (rubber part on door surrounds) commodog TJ Wrangler Technical Forum 6 07-12-2009 08:50 PM
What is this part called and how do i replace it? (engine/air intake part) AlTheKillerr Wrangler General Discussion 3 09-12-2008 09:08 PM
Lets Play..... What part is this part???? NEWtoTHEjeepLIF TJ Wrangler Technical Forum 5 08-31-2005 03:00 AM
? about YJ axle vaccum part.....WHAT IS THE NAME OF THIS PART? x19delta YJ Wrangler Technical Forum 9 04-28-2005 04:28 PM
