What other parts to replace? - JeepForum.com
post #1 of 3 Old 03-08-2010, 03:22 PM Thread Starter
mudbugII
94 YJ 2.5L. About 40k on new motor. Sporadically will NOT start. Turns over fine, fuel at rail at proper pressure, compression good on all 4 cyl. New coil, plugs, wires, distributer, coil pickup, correct voltage to coil from ecm when cranking. Checked sensor in bell housing, passes chilton's manual test. When it runs, it is perfect (for a 2.5 anyhow). I went to leave work, turned over but wouldn't start. Walked home, got truck, returned to work to pick up stuff (maybe 15 minutes later), just for hell of it, tried the key and the jeep started right up. Can't duplicate when it is at garage, have had 3 different mechanics work on it, no codes on computer. Completely random, has done it when dry, wet, hot, cold, etc. No pattern that I can find. Any suggestions?
mudbugII is offline
post #2 of 3 Old 03-08-2010, 04:53 PM
TheRealOldjeep
Could be that the CPS connector is intermittant. Used to have that problem on my kids comanche. Wound up just cutting off the plugs and soldering it. Never had a problem after that.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #3 of 3 Old 03-08-2010, 05:15 PM
idaholtby
When this problem presents it'self,... when the ignition is first turned on, and before you go to start... Does the CEL lamp come on? It should, which would mean the ECM is powered up and then in-turn the fuel pump and ASD relay. If the CEL lamp does not light when the ign is first turned on, then likely you have bad capacitors in the ECM and it is easily/cheaply fixed. If the CEL does not initially light, will it do so if you what a spell?
idaholtby is offline
johnny joints to replace replace re rubber cmc1 TJ Wrangler Technical Forum 6 06-16-2009 05:50 PM
Need to replace some parts. BEACHSAND TJ Wrangler Technical Forum 0 10-23-2008 03:31 PM
Hole in front softtop window...what parts to replace? Evil_Ed JK Wrangler Technical Forum 3 08-01-2008 02:53 PM
97 Wrangler: What parts should I replace for a damaged float arm? NORCALROOTS TJ Wrangler Technical Forum 0 05-19-2008 04:32 PM
Regearing - Which parts to replace? Meir10 JK Wrangler Technical Forum 17 11-30-2007 05:46 AM
