what other jeeps can I get a transfer case from? - Page 2 - JeepForum.com
post #16 of 23 Old 06-20-2013, 10:24 AM
roadyrob
1987 YJ Wrangler
check ebay, the 4 cyl. cases go really cheap. if your patient you might score a deal like I got. 70.00 shipped and it works great.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #17 of 23 Old 06-20-2013, 11:49 AM
XJ93
Why swap all those parts over? If you want all the parts the new one has why not rebuild the case and drive it and sell your old one? Or keep both and build the new one into a toy.
XJ93 is offline
post #18 of 23 Old 06-20-2013, 06:56 PM Thread Starter
roadgator
Thanks for all the responses.
I think I am going to swap interiors and while the dashes are stripped, use my wiring as reference to repair cut and butchered wires on the new jeep. The next thing I will do is swap tires to my rims. That will put me on 31's instead of 30's. The tires are new BF Goodrich. I am going to do as suggested earlier on here and leave the suspension lift on the new jeep. Once that is all done, I will take the transfer case out and see if it is rebuildable. If so I will get a kit and do it. I also plan on swapping the windshield frames and tailgates.
Once it is all done, I will put it up for sale.
roadgator is offline
post #19 of 23 Old 06-20-2013, 10:06 PM Thread Starter
roadgator
One other question, does it matter if a transfer case comes from an automatic to go on a standard?
post #20 of 23 Old 06-20-2013, 10:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The TJ section has specs on spline counts in the FAQ. I will work on gathering that information and making it accessible to all.
Anticanman is offline
post #21 of 23 Old 06-21-2013, 04:19 AM
jimbos76cj
Aw-4 up to 1990 is the only auto that shows having the 21 spline short input gear. Both of your cases are shot?
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #22 of 23 Old 06-21-2013, 06:10 AM Thread Starter
roadgator
No, mine is fine. I found one on craigslist from a 94 with automatic for 150. From what you are saying though, it will not work for the new Jeep. I will try to rebuild it when I get to that point, but if I come across a good one, I will get one.
post #23 of 23 Old 06-21-2013, 12:22 PM
XJ93
Also watch the length on input shafts for the t-case. I had one from an XJ and the input shaft was 1.5" shorter than my original case causing quite the fluid leak.
XJ93 is offline
