what is a normal idle speed at the normal operating temp? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > what is a normal idle speed at the normal operating temp?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 05-23-2010, 05:17 PM   #1
tkwok
I recently cleaned my throttle body along w/ the IAC valve motor. I was especially careful not to pull the pintle out while cleaning the IAC. After putting everything back, I noticed the idle speed on my YJ is around 650-750 RPM when the engine is warm. Is this a normal idle speed? Other than that, the jeep seeoms to be running very smoothly after the cleaning.
tkwok is offline   Reply With Quote
Unread 05-23-2010, 06:14 PM   #2
Cajun90YJ
That a good idle speed, and you should put a 195 thermostat in it.
Cajun90YJ is offline   Reply With Quote
Unread 05-23-2010, 08:02 PM   #3
tkwok
i forgot what temp. thermostat I have in there. It was put in over 4 years ago.
Unread 05-23-2010, 08:28 PM   #4
jfrabat
That's lower than what I get... Mine is around 850 RPM (on the dash, anyway!)
'94 YJ 2.5L with 4" RE lift, Adv. Ad. SYE, Woody Shaft, Superwinch EPi9.0, 62mm TB, FoMoCo e-Fan, SD30 and SD35 w/ARB-4.88, 165A alt., 4 KC aux lights, Aluminum Rad with BRX hoses, 33" BFG KM2 on 15" AR wheels, Sony sound system, Pavement Ends Hardtop, Bosch 19# Injector, Safari Snorkel, 95.5 Brakes
jfrabat is offline   Reply With Quote
