What are my options? - JeepForum.com
post #1 of 12 Old 08-07-2011, 06:30 PM Thread Starter
Lre78hd
I have 88 yj with 307 gears and 33/12.50s. I am looking to correct my speedo but from the sites I have found from my search don't show a gear for what I have.
Lre78hd is offline
post #2 of 12 Old 08-07-2011, 07:31 PM
Nickabis
I used a gps and got an e exact speed and looked at my speedo and and now I know I'm a of by 5mph or so, so I judge my speed that way.
Here is a chart for an xj I found searching google. May give you an idea.
http://jeep-xj.info/HowtoSpeedoGears.htm
How this helps
Nickabis is offline
post #3 of 12 Old 08-07-2011, 07:35 PM
Louie4
I use a speedometer on my iphone and I tested it with my '09 Civic and it's accurate. To change your speedometer it looks like you'll need a 25 or 26 tooth speedo gear based on the above link. I know Quadratec sells them but they are pricey IMO.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #4 of 12 Old 08-07-2011, 08:42 PM
clarkjdg
clarkjdg's Avatar
You need a (26 tooth long), I had to go 34 when I put mine on because I went 4.10 gears and a 8.8 rear axle, I just went to Ebay there is a "new" one on there for $39. all the other places like 4WD, or Quadratec they are around $75. to see the one on Ebay just type in Jeep 26 tooth speedometer gear. It is the one you need its a "long shaft" that fits 1966 up on all cable driven. Its just like mine but different tooth count and Ebay is where I got mine.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #5 of 12 Old 08-07-2011, 09:03 PM
4.7stroker
If you regear to 3.73 it will get you close enough and you will regain some of that long lost pep.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #6 of 12 Old 08-07-2011, 11:05 PM Thread Starter
Lre78hd
Thanks for the info. That would be my next question. Would regearing to 373 ( finding another jeep with the needed gears) be a wise move with the size tires I'm using. I'm not wanting to do alot of axle swapping and modifications.
Lre78hd is offline
post #7 of 12 Old 08-07-2011, 11:08 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I'd find a 4cyl. wrangler with a manual in a salvage yard and buy the axles. that way you would be able to swap in 4:10's on the cheap
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 12 Old 08-08-2011, 04:51 AM
Louie4
I agree with above. Find a donor YJ with an automatic and/or a 4 cylinder. They will have 3.73 or 4.10's. Unfortunately you'll have to swap axles but it's not that bad.
Lou
YJOTM July 2012
YJOTM February 2014
post #9 of 12 Old 08-08-2011, 05:41 AM Thread Starter
Lre78hd
For someone who rarely 4 wheels ( I like the open ride feel) would this be less of a headache than this 8.8 I see talk of? If so I would need to find a 4 cyl. Yj with which gears? Which would be more suitable 373/410? Would I need to just swap axles? When yall say axles Yall mean what mounts to the springs not the innerards right? Im Just wanting to be in the same dictionary.
Lre78hd is offline
post #10 of 12 Old 08-08-2011, 07:01 AM
Skydmark1
This is precisely what I plan to do. I've got a 95 on 33's with the stock 3.07 gears. My dad has a YJ that's a 4cyl 5spd he only wants $800 for it. The frame is junk but I could use the axles, the soft top, the half doors, the driver's fender, and a few other parts. Then sell the rest!
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #11 of 12 Old 08-08-2011, 07:12 AM
Louie4
An 8.8 is an ideal swap for folks with larger tires, lockers and ones who hit the trails a good bit. The lug pattern is the same and the width is close enough. However it would require some cutting and welding. I would just focus on finding a 4 cylinder YJ, it will most likely have the 4.10's which will give you a good bit of pep back. You'll still have the D35 but it doesn't sound like you're going to beat on it and you don't have a locker.
When we say swap axles we mean just unbolting and bolting back up to the leaf springs (in this scenario). However if you swap an axle from a different model/make then it will require some fab work. If you start taking gears out then it's a gear swap.
Lou
YJOTM July 2012
YJOTM February 2014
post #12 of 12 Old 08-08-2011, 07:24 AM Thread Starter
Lre78hd
Okay that's probably what I will do is find a 4 cyl. Would it be a unbolt/ rebolt scenario if I stayed in the 88 to 93 year range? No fabbing? I'm just looking for the easiest and most cost effective route.
Lre78hd is offline
