What is this on my new engine? - JeepForum.com
post #1 of 27 Old 01-20-2010, 04:16 PM Thread Starter
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Anyone recognize this fitting that is sticking out of the oil filter mount on my new engne?
I screwed the old adapter from my old block in there dead center, but don't want to pull this 1.5" rod out until someone seconds my opinion that it is from the reman process and got left there....
Help.
Had this in my rebuild thread, http://www.jeepforum.com/forum/f12/t...ilding-869713/ but wanted you to see it incase your not a thread fan...I just need some quick attention on this one.
hotelconucc93 is offline
post #2 of 27 Old 01-20-2010, 04:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I can't see your pics, they're blocked here at work, but I think you might get an explanation in this article.
Oil Filter Conversions
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 27 Old 01-20-2010, 04:36 PM
bulrokyj
Looks Like just a spring pin. I think it was a leftover. It would be impossible to screw the filter on with that there. Im not !00% certain tho.
bulrokyj is offline
post #4 of 27 Old 01-20-2010, 04:37 PM
jbolty
jbolty's Avatar
There is a roll pin sicking out about a half inch right next to the threaded part for the filter. Maybe 1/4 diameter. Odd. Maybe someone can snap a pic without a filter to compare. What engine?
jbolty is offline
post #5 of 27 Old 01-20-2010, 04:42 PM
dodger889
There should be a 90* angle oil adapter that is what hold it in place from turning.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 27 Old 01-20-2010, 04:50 PM
4.7stroker
What he said.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 27 Old 01-20-2010, 04:50 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Ah! The first pic had the block number for you tech guys. Block 53008405, 1991 YJ 4.0 I6 242.
Sorry!
Max, when you get outta work, you gotta look...your article is neat but I don't know if it applies here. I would love an angle, but the article was not 91 YJish so is it possible?
post #8 of 27 Old 01-20-2010, 04:51 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Thats the catch. There was NO adapter on my old block, just a male-male nipple, now seen screwed into the middle of the pic with the mle threads out for the filter.
post #9 of 27 Old 01-20-2010, 05:01 PM
msprooch
weird...I say break it off, but its not my new remanned engine, btw your build looks sweet. Im stocking your build lol.
msprooch is offline
post #10 of 27 Old 01-20-2010, 05:03 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sorry!
My wife's '93 has an XJ 4.0L in it with an angle adapter. The angle adapter can be used on any 4.0L block, to the best of my knowledge.
I actually prefer having it on hers and I will install one on my '91 4.0L if I ever get around to it.
Max
Mean Max is offline
post #11 of 27 Old 01-20-2010, 05:12 PM
Reverb
If a 90 degree adapter should be there - shouldnt the threaded bit be missing?
Reverb is offline
post #12 of 27 Old 01-20-2010, 05:21 PM Thread Starter
hotelconucc93
2010 YJ Wrangler
Took the threaded nipple from my old core and placed on this block. My old core has a HOLE where that rod went, but no rod. I don't want to break this off until totally sure.
Max's article (which I like, since I was researching this like MAD yesterday on google and came across similar...his article is better by far) shows the rod in some pics, or what I think is the rod.
I'm so perplexed. If you have ever seen my flowchart, I am at about beer 12 on this and googled out, so I posted this!
I have even read the FSM and Haynes with no luck.
post #13 of 27 Old 01-20-2010, 05:26 PM
4.7stroker
I got a 90* adaptor from a Cherokee I prefer it over the other options available over the years.
Dwayne
[url]
[url]
post #14 of 27 Old 01-20-2010, 05:28 PM
msprooch
I think you need more beer then you won't care anymore and just yank it out.
msprooch is offline
post #15 of 27 Old 01-20-2010, 05:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The pics in the link are fairly blurry, but I think the part the author refers to as a "little tube" is what you are describing on your 4.0L block.
I don't think it's a "tube" at all. I believe it to be a roll pin, as previously mentioned by dodger889, that keeps the adapter from spinning.
If you are NOT using a 90 degree angle adapter, I think it should be removed, as opposed to breaking it off.
Max
Mean Max is offline
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 07:00 PM
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 08:57 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
