What is the maximum backspacing i can have with 33's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What is the maximum backspacing i can have with 33's
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-24-2014, 05:19 PM   #1
austinphe
I am planning on buying a set of 33x10.50r15 tires for my 95 yj. with a 15x8" rim and I just wanted to find out what the maximum backspace i can have without the tires rubbing against the leaf springs and also without adjusting the steering stops. any help is appreciated!
austinphe is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 07:25 PM   #2
The_Goob
Hell on Wheels
The_Goob's Avatar
my 31x10.5 rubbed leafs at full lock on 5 or 5.5" backspace. . I would say 4-4.5 would be the most. given the 33 will touch even sooner.
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 03-25-2014, 05:28 PM   #3
austinphe
ah, i've gotta measure my D-window steelies, i think they may be 4" backspaced. thanks for the help
Unread 03-26-2014, 12:00 AM   #4
baritone_mike
I have 3.75" of backspace on a 15x8 wheel with 33x12.50. My tires are within a tenth of an inch from rubbing the springs at full lock.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 08:07 AM   #5
StanF
For most Wranglers, 3.75" of backspacing is recommended
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is online now   Reply With Quote Quick reply to this message
Unread 03-27-2014, 11:09 AM   #6
austinphe
awsome, if 33x12.5 dont touch the 33x10.50 should be fine. thanks allot for the help!
Unread 02-08-2015, 12:48 AM   #7
Cheever
How far does tire stick out from body.. would 6 in flarez be to much
Cheever is offline   Reply With Quote Quick reply to this message
33" tires , backspace , backspacing , offset
