What locker do I want - JeepForum.com
post #1 of 7 Old 11-11-2001, 11:18 AM Thread Starter
jeepnmud
I want locker for the front of my 95YJ, but I'm not sure if I should get the soft-locker or the air-locker. I have 2 problems...... 1. I am new to this location, so I don't have a mechanic that I trust yet. 2. I am a woman so I am getting a bunch of crap. So I thought I would ask the perfessionals. What are the ups and downs of both. I'm thinking of an air locker.
Jen
jeepnmud is offline
post #2 of 7 Old 11-11-2001, 11:43 AM
evilpsych
evilpsych's Avatar
well if you got the $$$$$$ go with the ARB.. have you upgraded the ring and pinions in your diffs? it's especially important if you have larger than normal tires.. will save you a bit on gas and your acceleration will be a bit better too.. (wont stall the engine) if you havent done your tires yet.. i'd hold off on installing the locker, unless you have no desire to go to larger tires.. the ARB costs bout $650 per axle i believe, not including labor.. anyway.. if you get the gearing upgraded at the same time as the locker install, it'll get it done while the diff is open and dismantled which will save you money if you decide to do it later. I recommend at least 4.10 gears if you're goin bigger than 31" tires.. there are a lot of sites that have a nice graph that show you what RPM range you'll be in for a given tire size and gearing..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 7 Old 11-11-2001, 11:45 AM
evilpsych
evilpsych's Avatar
oh.. there are no ups or downs with the ARB air locker, it acts like an open diff when it's off and it's one of the best, if not the best locked differential when it's on. in a rear application, it saves you from roasting your inside tire on the streets by keeping it open on the road.. also reg lockers handle a bit different in slick road conditions..
A
post #4 of 7 Old 11-12-2001, 03:30 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
One of the guys in our club has ARB in front and back .. and his only complaint is the hoses .. he can never get a decent seal to keep the air going properly.
His other complaint is the hole drilled into the housing .. he has had a leak or two there.
He says overall, its a decent setup, but here in Canada, its a very expensive setup.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 7 Old 11-12-2001, 05:44 PM
osburn
osburn's Avatar
I've been running ARBs a long time. Ran them in my stock axles, and wouldn't have anything less in these double-throw-me-down-*****'n axles. I have never, repeat never, had the air leaking problems that everyone tells you ARBs have. Granted, you have to pay a great deal of attention to your air system. You want to make sure your lines are properly fitted and run so as not to get caught up on anything and not too close to anything hot such as exhaust.
Also, don't waste your time with the ARB compressor. It's junk. Absolute junk. I went thru three of those damn things.
Now those lockers I ran in my stock axles did not come without problems. The first locker installed in my Dana 35 lasted about 3 years then the cross-shaft broke. ARB footed the whole bill. Locker, ring & pinion it destroyed and labor. The second locker, same problem, another busted cross shaft. When I called ARB they insisted my axle was bent. I insisted it was the locker since the 4x4 mags had just touted their new design (with a bigger cross shaft of course) for the Dana 35. I had to take the axle to MIT for inspection. MIT checked and it was bent, but not enough in their mind to cause the failure. ARB agreed to send me the newly designed locker at their cost. I had the axle straightened and the locker installed at my expense.
I didn't have any other problems with the locker. The Dana 35 and Dana 30 axles are both under my son's Jeep now and he hasn't had any failures either.
Most of the stuff you hear about ARBs are just rumors. Stuff guys pick up from other guys and they spread these rumors as if they were fact. I don't dispute your story one bit Naekid. You were specific. But most guys say "I see them breaking all the time." Or something along those lines. I tend not to believe them. Unless the lockers they're seeing are the old design, which came off the shelves like 4-5 years ago.
Matt Osburn
Score 1032
osburn is offline
post #6 of 7 Old 11-13-2001, 01:43 PM
Cody_91YJ
If you can afford it, then definately go ARB. I have see 2 rigs tear lines on the trails, but I think that was due more to not thinking out installation as far as the hoses were concerned.
If you don't go ARB, I'd go with a Lock-Rite or No-Slip. I run one up front and never had a problem and haven't heard of anyone having problems with them either
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #7 of 7 Old 11-13-2001, 03:06 PM
RodeoRob
RodeoRob's Avatar
Of course you could always go with an OX... same deal with the ARB in being selectable, but uses a cable (thick one at that) to activate rather than air lines. Cost is about the same as well, maybe a little cheaper when you figure on not having to buy an air compressor. They are relatively new to the market... I've heard nothing but good remarks about these, but then again ARB has the history.
www.oxtrax.com
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
