What is the little metal box that the master cylinder goes to called? - JeepForum.com
post #1 of 4 Old 05-03-2011, 11:59 PM Thread Starter
tammaru
Hi All,
Quick question... lost my brakes, brake line to front left wheel rusted through. ok. Made a new line, installed, uh oh I cross-threaded it on one side. What is the metal router(?) below the master cylinder that splits the 2 lines from the master to 4 and directs the brake fluid to the four wheels called?
Tarmo
tammaru is offline
post #2 of 4 Old 05-04-2011, 12:06 AM
Major Pain
Junior Member
Major Pain's Avatar
2011 JK Wrangler
if I understand your description correctly it is the proportioning valve that splits the brake pressure to front and rear. splits it something like 70/30 more to the front less to rear. not sure if it evens out as you apply more pressure but I gutted mine out when it became an off-road toy more than daily driver.
Major Pain is offline
post #3 of 4 Old 05-04-2011, 12:26 AM
mazyj
I believe the whole thing is called the distribution block. The proportioning valve is integrated into the distribution block on most stock applications. I just replaced mine with an adjustable unit for when i have disks in the rear. To replace a stock one i would just go to a junk yard.
Here's the one i used if its of interest http://www.ssbrakes.com/commerce/det....cfm?nPID=8862
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #4 of 4 Old 05-04-2011, 09:23 AM Thread Starter
tammaru
Cool. Thanks for the quick reply! I think the junkyard might be the way to go... or Oconee! Can't find it anywhere else.
tammaru is offline
New master cylinder didn't fix pos ax-5!! XsaltlifeX YJ Wrangler Technical Forum 7 10-22-2009 07:12 PM
How do you know whitch one is bad, Master Cylinder or Slave Cylinder? Morgan_TJ TJ Wrangler Technical Forum 19 08-06-2008 09:00 AM
master cylinder jeeplaredo89 YJ Wrangler Technical Forum 0 11-12-2007 03:36 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
Master Cylinder newbee YJ Wrangler Technical Forum 7 06-24-2004 08:38 AM
