what line is this ? - JeepForum.com
post #1 of 6 Old 08-07-2011, 06:56 PM Thread Starter
02grandy
what line is this ?
dont have a pic but it fronts from the gas tank and looks like a metal brake line along the driverside frame rail up into a rubber line on the driver side firewall in the engine compartment. i think its a breather ??????? at the end of the rubber there was nothing maybe the lost breather . what is all this im talking about ? thanks
02grandy is offline
post #2 of 6 Old 08-07-2011, 07:04 PM Thread Starter
02grandy
92 yj 2.5l
02grandy is offline
post #3 of 6 Old 08-07-2011, 07:06 PM
Lre78hd
I think it's the tank vent that's supposed to tie in to the charcoal canister
Lre78hd is offline
post #4 of 6 Old 08-07-2011, 07:06 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Mad guess would be it is the line that goes to the charcoal cannister.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 6 Old 08-07-2011, 07:07 PM
Noltz
YJ Wrangler
Is it quite small in diameter? If yes, then it's likely the vent line
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #6 of 6 Old 08-08-2011, 05:17 PM Thread Starter
02grandy
the line is the same as the brakeline then it around the firewall area it changes to a mucher larger rubber piece but appears to be a breather
02grandy is offline
Jeep Interior/exteror Hurculined, Line-X, Rhino Line inglisleslie TJ Wrangler Technical Forum 23 06-07-2013 03:53 PM
Repairing a transmission line - mid line rust hole satchownz TJ Wrangler Technical Forum 1 06-13-2011 07:11 AM
Transmission cooler line leak at hard line to rubber connection herath JK Wrangler Technical Forum 5 02-10-2011 08:18 AM
steel line to soft line for the rear axle removal question Selafane YJ Wrangler Technical Forum 1 08-15-2010 02:13 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
