What kind of rear end is on my Jeep? - JeepForum.com
post #1 of 5 Old 03-03-2007, 08:10 AM Thread Starter
GooseAbuse
How do I identify what kind/size of rear end my Jeep has? I went to check the rear fluid and instead of a bolt in the fill hole there is a rubber Dana plug. "350" is stamped on the diff and Dana logo is on diff cover along with some more numbers.
Is there a trick to removing the rubber plug or can I just pop it out with a screwdriver? I don't want to booger it up.
1995 YJ (almost bone stock) <- that's about to change!
1999 WJ fo-by-fo with a fo point O
GooseAbuse is offline
post #2 of 5 Old 03-03-2007, 08:23 AM Thread Starter
GooseAbuse
Nevermind the dumb "what kind of axle do I have" question. 35C.
What about the plug? Just pop it out?
post #3 of 5 Old 03-03-2007, 09:19 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The plug should just pop out
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 5 Old 03-03-2007, 09:31 AM
northjeep
Jeep parking ONLY
northjeep's Avatar
it is a ***** though...I used two flat head screw drivers from either side....otherwise....just take the cover off...inspect the crappy gears in there, and pop the plug out while the cover it off.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #5 of 5 Old 03-03-2007, 09:43 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If the rear diff cover looks like this except it has the rubber plug like you mentioned - yep, it's a D35. This cover is for a D35 too, but just an earlier model non c-clip D35.
As far as the plug goes....they tend to get brittle and easily crack and tear over time. Be carefull removing it because you can easily tear it & then it'll start leaking fluid and be a mess.
If you do decide to change the fluid, simply remove the whole cover carefully so as to not give yourself an oil spill, then remove the plug from the inside pushing it gently out. Clean the mounting surface of the diff & cover. Inspect the diff internals paying close attention to the gear wear and potential chips in the spider, side, and ring & pinion gears and also clean all the fine metal shavings out from the bottom. Apply some RTV gasket sealer to the cover & mounting surface. Reattach the cover. Refill with appropriate grade oil, then put the plug back in. I also like to spin the diff while it's opened up to further inspect things.
Joe Dillard is online now
what kind of rear axle? jeepkween YJ Wrangler Technical Forum 2 04-03-2009 11:57 AM
What Kind Of Locker Are You Running In The Rear metallatem YJ Wrangler Technical Forum 39 10-02-2008 12:37 PM
How do I tell what kind of rear ends I have? jagerbombardier TJ Wrangler Technical Forum 8 07-31-2007 03:53 PM
what kind of rear shocks to get jeepindika YJ Wrangler Technical Forum 4 03-19-2007 09:41 PM
Just rear ended. What kind of damage do I look for? STW TJ Wrangler Technical Forum 7 01-18-2006 11:36 AM
