What the heck is this and is it causing grinding? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What the heck is this and is it causing grinding?
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-24-2015, 01:17 PM   #1
bthompson12994
I did some quick searching and found nothing. I bought my second Jeep today. I sold my 2004 rubicon earlier this week and got behind the wheel of a 1988 2.5l yj today. On the 2 hour drive home it was doing great and I was handling the 5 speed alright (never driven stick before)(I'm only 20). After about an hour and a half it started grinding in every gear except 4th. I limped her the rest of the way home in an angry panic. Now I'm not scared to tackle a project and most times I pull through alright, so I climbed underneath and gave a quick inspection to find this random plug looking thing hanging from the passenger side of the tranny. What the heck is this? Where does it go? Will it fix my grinding problem or am I out of luck.
bthompson12994 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 01:20 PM   #2
bob8619
I think thats the reverse light switch. Whats left of it anyways.
bob8619 is online now   Reply With Quote Quick reply to this message
Unread 01-24-2015, 01:22 PM   #3
bob8619
The part that goes into the tranny housing has a metal ball on the end. I suppose its possible that the ball popped into the transmission but I doubt it. So, it could be related to the grinding but maybe not.
Unread 01-24-2015, 01:48 PM   #4
Anticanman
Follow me
Anticanman's Avatar
Welcome to the Yj world. You would be best off draining the transmission and looking very closely at what comes out. Note the color. The brass synchro gears can start shredding and then when enough pieces are lodged inside they tear up the harder steel components. However, you may jus be low on fluid.
Have a looksee and welcome to the square side.
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread Today, 11:21 AM   #5
bthompson12994
It's the 5th gear switch, broken off. No big deal as far as I can tell.
Unread Today, 11:24 AM   #6
bthompson12994
Thanks for all of your input.
Unread Today, 12:02 PM   #7
Mark05059
never heard of a 5th gear switch... whats its purpose?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread Today, 01:07 PM   #8
jhrebs
1987 YJ Wrangler
I would've guessed its the indicator that controls the little arrow on your dash to tell you when to shift. Either way, your first step is drain fluid and inspect. Do the simple things first. And an added bonus you change the tranny fluid.
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is online now   Reply With Quote Quick reply to this message
