What have I gotten myself into? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What have I gotten myself into?
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 04-16-2014, 11:04 AM   #1
BHawkmeck
1983 CJ7
Hi everyone,
I'm usually creeping over on the CJ side. Here is my story and what I have gotten myself into. After numerous months of making fun of my the girlfriend's 2012 Compass with 2wd drive, she went out and found a really clean 87 YJ 4.2/ (BA5/10 with synco's going out) 4.88 on 31's. I have replaced the rotted out rear frame rails and replaced the body mounts. A good friend of mine's daughter rolled her 98 cherokee 3 times nose/tail. Shes fine but the Cherokee isnt. For free im getting the whole drive train. 4.0 AW4 NP who really cares. I plan on doing the 4.0 EFI OBDII Head conversion and AW4 swap. By trade i'm a 30 year helicopter mechanic for the Guard full time and a A&P. Been wrenching on cars since I was 10. Have done quiet a few LS conversions in older vehicles. I just wanted to give everyone some info so I dont sound like a complete NOOB. I hope if I cant find it on the search engine, maybe someone on here has run across the problems I know I will come across.
Thanks everyone and I will start posting pictures as I begin this little adventure.
BHawkmeck is offline   Reply With Quote Quick reply to this message
Unread 04-16-2014, 11:17 AM   #2
Varnish
Why not just take the complete 4.0 as is from the XJ? The motor mounts will transfer. I've done a couple swaps, last year a '00 XJ drivetrain into a CJ. My method is take the complete engine wiring harness and drivetrain out of the XJ, strip out what I don't need from the XJ harness (AC/cruise/lighting) and make the necessary connections at the YJ bulkhead connector. Lotta pouring over wiring diagrams. For the CJ I had to run a few extras like the rear electric fuel pump but the YJ should already have that wiring from the bulkhead back to the tank as the '87 4banger was fuel injected. You can graft in an electric fuel pump into your existing YJ tank or use an external. Get a '91 YJ vehicle speed sensor which you can wire into the XJ PCM but has the passthrough for your cable-driven speedo. The aw4 transfer case will be slightly clocked down but I was able to fit one in my YJ over the stock crossmember with my 1" body lift, you can also redrill the tail housing to reclock it or get a clocking ring.
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote Quick reply to this message
Unread 04-16-2014, 12:08 PM   #3
zeus87gn
1987 YJ Wrangler
The 4.0l head conversion to the 4.2 is the way to go IMO....if the bottom end is up for it
Many of the original factory built 4.2s weren't built very well so keep it in mind before actually doing the complete comversion
You may want to give it a compression and bearing clearance check
I also have a feeling you're going to be geared too low by the time your done
Again, JMO
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
Holley Carb thread
zeus87gn is offline   Reply With Quote Quick reply to this message
Unread 04-16-2014, 12:09 PM   #4
BHawkmeck
1983 CJ7
Varnish,
The 4.0 in the donor vehicle has over 200K, the 4.2 has 2k on a fresh rebuild that I have already nuttered. I plan on grafting in the electric fuel pump from the cherokee to the original YJ tank. As for wiring I have a few items left over from being in aviation for 30 years. I plan on making a full circuit breaker panel with resetable breakers like what you find in aircraft. A custom relay panel to control the fuel pump, headlights, cooling fans, winch and anything else that has a high current load. I have all the wire diagrams allready layed out with both types of vehicles. I had planed on just reclocking the TC.
The reason I want the fuel injection and automatic is that my soon to be wife cant drive a stick to save her life. We have tried and tried and both came to the conclusion that she just cant drive a stick. Dont get me wrong, she loves going on the trails with me in my CJ and really wants to get into it. There are some people that just cant seem to master driving a stick.
Unread 04-16-2014, 12:12 PM   #5
BHawkmeck
1983 CJ7
Here is my CJ
Unread 04-16-2014, 12:13 PM   #6
BHawkmeck
1983 CJ7
The only pic of Laura's YJ I can find.
Unread 04-16-2014, 12:18 PM   #7
BHawkmeck
1983 CJ7
What I do for a living.
Unread 04-16-2014, 12:45 PM   #8
Varnish
Sounds like a plan. The aw4 is a great tranny, I love it. Zeus may be on to something with the gear ratio, I know the cherokee aw4 guys typically suggest 4.56 with 33s so 4.88 and 31s may be a bit tall if the thing will see higher speeds.
'99 XJ 4dr SE
Unread 04-16-2014, 01:22 PM   #9
YJ4LIFE
search on that tranny and 4.2l if there's any internal/external balancing issues.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote Quick reply to this message
Unread 04-16-2014, 01:55 PM   #10
BHawkmeck
1983 CJ7
YJ4LIFE,
Good question. I did some looking just now and the I6 are all internally balance. Flex plates shouldnt be a issue. I hope LOL
Unread 04-16-2014, 02:00 PM   #11
The_Goob
Hell on Wheels
The_Goob's Avatar
Interesting project, subbed to watch. Im about an hour and a half up the road from you.
The_Goob is online now   Reply With Quote Quick reply to this message
Unread 04-16-2014, 03:38 PM   #12
superj
1987 YJ Wrangler
You guys come tdy to get depot level training on those where I work.
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:41 AM   #13
BHawkmeck
1983 CJ7
Hi everyone,
Been awhile since I posted last. Life got in the way for a bit. Started on the body work. 7-10 layers of paint on this rig. Decieded to go down to metal. Finding some issues but nothing horrible.
Unread 05-19-2015, 09:56 AM   #14
LVJeepster
Pretty sure anyone who has worked on a jeep has asked themselves the same questions. The pics of the pieces your posted look pretty clean... yeah for small things.
LVJeepster is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 08:20 AM   #15
BHawkmeck
1983 CJ7
The donor Jeep for the FI and the drivetrain. It actually started and drove up on the trailer. Lower end of the engine has a pretty good knock so it will be a head/FI swap.
