What goes in this hole in the fuel tank? - JeepForum.com
post #1 of 4 Old 10-01-2013, 06:21 PM Thread Starter
defmornahan
1987 YJ Wrangler
I wondered why I always smelled gas.
Anyway, so there's this hole in the fuel tank that looks like a plug has fallen out. Any way to find one of those separately? What is that part's name? It looks like it's the same size as that vacuum fitting on the other side of the tank.
A jeep is managed; it is not cured.
defmornahan is offline
post #2 of 4 Old 10-01-2013, 06:44 PM
YjJeeper94
From what I remember there's supposed to be a fitting just like the one of the right side of the tank.
Edit: found a picture.
YjJeeper94 is offline
post #3 of 4 Old 10-01-2013, 06:51 PM
J33Pyj
they are commonly called roll over valves. I had to replace both about 2 yrs ago. Orielly had them like 10 bucks each.
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
post #4 of 4 Old 10-01-2013, 08:06 PM Thread Starter
defmornahan
1987 YJ Wrangler
Natch. I eventually figured it out, too--I really am missing one from my TJ--but as it turned out the other vent was just dangling from the disconnected vac line underneath the body. Thanks!
