What gears should i put in my 88 yj - JeepForum.com
post #1 of 6 Old 07-06-2013, 12:36 AM Thread Starter
bailes86
I have a 88 yj. Not sure what gears are in it but with my lift and 33 inch tires they are not good enough. I want to cruse in first gear about 5 mph. And at least go 65 mph in 5th gear. I just want power in every gear. I just want power in every gear
bailes86 is offline
post #2 of 6 Old 07-06-2013, 03:18 AM
fbv193
Need more info, what engine, tranny, and what are your current gears ? Manual tranny Jeeps generally require lower gearing than autos.
Oh, I guess you have a 5 speed, from your post. I would say somewhere between 4.11 and 4.56 would be about right for 33s if you have a six cylinder and 4.88s if you have a 4 banger.
fbv193 is offline
post #3 of 6 Old 07-06-2013, 03:26 AM Thread Starter
bailes86
Thanks for the reply. Yes I have the 6 cylinder with 5 speed trany
bailes86 is offline
post #4 of 6 Old 07-06-2013, 09:51 AM
rambo3489
With the 6 I would vote for 4.56 as well. I have 4.88s in my 6 with 35's and its PERFECT. With 33"s 4.56 will net you about the same. HOWEVER if you EVEN plan to go bigger even if you find yourself saying that looks good on 35"s go with 4.88's and go a little slower on the freeway.
With 4.88s and 33"s you will be running 2600 RPMs at 65 on the freeway. Which isn't the end of the world. But the old girl would be pretty rung out.
As per: http://www.grimmjeeper.com/gears.html
Play with that calculator. By far the best out there.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #5 of 6 Old 07-06-2013, 10:38 AM
wendell
1987 YJ Wrangler
Yep, I agree, 4:56 is the gear to have.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #6 of 6 Old 07-06-2013, 03:49 PM Thread Starter
bailes86
Thank y'all for the comments, very helpful. I think i will go with the 4.56's considering I am not going any bigger than 33's. Once again thanks for the feedback, and I'm sure ill have more questions down the road
bailes86 is offline
