What gears do I have? - JeepForum.com
post #1 of 13 Old 05-03-2010, 02:35 PM Thread Starter
qvfd153
1981 CJ7
I recently bought a 93 yj 4.0. I am having a hard time finding what gear ratio is in my front Dana 30.
The outer tag on the cover reads 52068202 55 610393-5
Found out my jack stands are to short to lift the jeep up to count revolutions
Not sure if pics will help
qvfd153 is offline
post #2 of 13 Old 01-31-2011, 10:05 PM
kylebirk
if you find out, tell me, I have the same numbers, same problems
kylebirk is offline
post #3 of 13 Old 01-31-2011, 10:14 PM
burnout189
count the teeth
take the number of teeth on the ring gear, divided by the number of teeth on the pinion gear. thats your gear ratio
BARNHART'S AUTO REPAIR
burnout189 is offline
post #4 of 13 Old 01-31-2011, 10:20 PM
The1AndOnlyBug
whats the gear ratio of the rear? does the 4 wheel drive work? if it does, see if there is a tag on the rear diff that you can read
Edit: checked your profle it says you got a locked d35 with 3.73's, if it works then you obviously have 3.73's in the front.
Edit2 and just curious I've got 33's Im about to get a front axle with 3.73's to match the 8.8 in the rear how do you like them for driving/wheeling?
My Vehicles
'89 Wrangler 4.2 .....Sold......
'08 Grand Prix GXP 5.3 V8 303 hp 323 ft-lb tq, my baby =D ..... SOLD.......
'94 wrangler 4.0, parted out/traded off
'94 Wrangler 4.0 K&N cold air, bored throttle body, head polished, Comp cam, 4.5" RE extreme duty, ubolt flip, 1" booms, 1" daystar body, M.O.R.E shock mount extenders rear, shock mount extenders on front, D35 W/ Richmond Lunchbox, 4.56 Gears, 35/12.5/15 Pro Comp M/T, Black D steelies, Front bumper W/ Stinger and winchplate (Armorology), Warn XD9000I, Dakota seats,Kenwood KDC-MP342U head unit, Soundbar with Kicker DS65's, Kicker DX200.4 Amp, Kenwood 6X9 on bottom of rollbar, Infinity 4X6's in dash, Tuffy Glovebox, 4 100W Daylighters, and a CJ hardtop.
2012 HD Night Rod Vivid black stock =D
R.I.P. Chad Daniel French 29 July 1982 - 25 Oct 2010 I'll Miss you Bro
The1AndOnlyBug is offline
post #5 of 13 Old 02-01-2011, 12:15 AM
timatoe
timatoe's Avatar
I had 3.73's on 33's for a long time, it wasn't too bad, but would've like to had at least 4.10's. 3.73's on 35's was awful.
OP, if you don't have a solid shaft on the passenger side you can just lift the driver side tire and rotate it. Like mentioned above if you know the rear it's quite likely the front's the same.
timatoe is offline
post #6 of 13 Old 02-01-2011, 09:22 AM
Renegade88
I had chrysler send me a build sheet for me. Seemed a little easier than pulling the diff off. I have 3.55 's.
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline
post #7 of 13 Old 02-01-2011, 10:32 AM
Mark05059
thats all fine and good until someone changes gear ratio's after the fact.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 13 Old 02-01-2011, 11:10 AM
lclark2074
if you got the cover off then count. this way you will be right . anuther way you can check is tape a pece of string on the bottom of the front drive shaft. mark your front wheel on the bottom. with 4wds engaged drive 1 wheel rev then count the string raps ands %. this will not tell you small diff like 410,411 but it will tell you big like 307,373
night crew 226
lclark2074 is offline
post #9 of 13 Old 02-01-2011, 04:22 PM
Mazdarx
Also the majority of the Renegades had the 3.55 gears to compensate for the 30" tires that came stock on them.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #10 of 13 Old 05-19-2011, 09:52 AM
GilNewJeeper
2008 KK Liberty
Maybe tgis can Help
Check this pictures
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #11 of 13 Old 05-19-2011, 10:20 AM
MJMPC
What are the numbers stamped on the side of the ring gear?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 13 Old 05-19-2011, 02:49 PM
uhohthe50
3.55's. Go to this link > http://www2.dana.com/expertforms/deabill.aspx and enter in the BOM number. In your case, your number is 610393-5
uhohthe50 is offline
post #13 of 13 Old 05-19-2011, 03:27 PM
915kingwrangler
the numbers stamped on the ring gear can tell you your gear ratio, easiest method
915kingwrangler is offline
1993 , axles , dana 30 , gears , lockers
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 09:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 10:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 07:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 10:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 11:54 AM
