what gear ratio does my 89 yj have - JeepForum.com
post #1 of 5 Old 04-01-2002, 08:37 AM Thread Starter
Black Dragon
I have an 89 4.2L 5sp YJ and want to know what gears I have, I really don't know what it means but want to find out. Is it my transfer case or my axels?
Please help
Black Dragon is offline
post #2 of 5 Old 04-01-2002, 08:52 AM
JRowe
3.07
94 YJ, 4.0L, 35" BFG MT, 3" suspension, 3" body,
JRowe is offline
post #3 of 5 Old 12-28-2010, 02:25 PM
jhumphrey
Usually its on a tag at the 9 o'clock position on the rear differential.
I have an 87 YJ and the tag is unreadable. What I can read makes no sense, so I have no idea what my ratio is. My VIN comes back as a Laredo, but I didnt think Laredo's existed in 1987. Mine doesnt have a chrome grill, full doors, or a hard top, so I think mines a standard. I guess the only way Ill know is to do the spin test....
jhumphrey is offline
post #4 of 5 Old 12-28-2010, 02:49 PM
dadstoy
Your gear ratio, when normally asked, is your axles. As stated, you probably have 3:07's
Your transfer case is also geared down. It is 2.72:1
dadstoy is offline
post #5 of 5 Old 12-28-2010, 05:45 PM
MJMPC
From the FAQ.
What gears do I have in my Jeep?
I4 Automatic - 3.73:1
I4 Standard - 4.10:1
I6 Automatic - 3.54:1 (normally)
I6 Standard - 3.07:1, 3.54:1 or 3.73:1 - must verify with the tag on the axle or by pulling the differential cover and reading the numbers stamped in the ring gear or by counting revolutions of wheel versus driveshaft.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
