What gear ratio do I want? - JeepForum.com
post #1 of 4 Old 11-19-2011, 03:31 PM Thread Starter
Virjeep
I drive a 87 yj, 6cyl, auto trans and love it. It has dana30/35 axles, with the 35 lincoln locked. I do most of my driving on the road (altho its not my DD), and really don't like the rear locked. So.... Its time for a new setup, and I'm thinking 8.8. The question is : I currently have 3.54 : 1 gears and really don't have a problem with them. I seem to have plenty of power and I can go up and down the road with very little downshifting. I can get the 8.8 with these gears and not have to do anything with my front axle. I currently run 33" tires and don't plan on going any bigger, and will probably put a lunchbox locker in the front and maybe a detroit locker in the rear. I use my jeep mainly for hunting so it sees mud and snow, very few rocks. Do you guys think the 3.54s will be alright for me or should I go to 4.11s. Your thoughts?
Virjeep is offline
post #2 of 4 Old 11-19-2011, 04:05 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There is also 3.73 which is as common or more common than the 4.10. I would pick a ratio and stick the Detroit up front when you regear because you'll need a new carrier with the switch. What are your plans with your jeep? Are you going to go bigger with tires? I'd maybe go 4.10 and leave an option to put bigger shoes on.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 11-19-2011, 05:51 PM
soonermatt
3.73 limited slip 8.8 rear axles are very common. I bought one for $250 last week. Limited slip is great on the street and helps in snow and mud. You could come across matching gears up front with little trouble.
soonermatt is offline
post #4 of 4 Old 11-19-2011, 06:59 PM
Apollo12227
I love my Detroit OP, if you have to regear it's a great locker even in the rear. I never really notice mine while driving and it does amazing off road.
Apollo12227 is offline
Gear Ratio/Crawl Ratio is my Jeep's Achilles Heel on Advanced Trails (Driving Tips?) TrailRated2011 JK Wrangler Technical Forum 19 04-13-2014 05:59 PM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
