What gear ratio do I have/Tag # - JeepForum.com
post #1 of 4 Old 08-09-2010, 06:52 PM Thread Starter
mark12010
Here is my tag # can someone tell me what gear ratio I have
5300 8518
3 07 605423-7
I am looking to go to 4.11 gears but I am hearing about having to change my case or carier or something about "case break" Can someone give me the scoop on this.
Thanks
mark12010 is offline
post #2 of 4 Old 08-09-2010, 06:55 PM
dadstoy
3.07..........you will need another carrier
dadstoy is offline
post #3 of 4 Old 08-09-2010, 07:39 PM Thread Starter
mark12010
Will I need a new carrier front , rear or both ?
post #4 of 4 Old 08-09-2010, 08:01 PM
Louie4
Yes you will need new carriers for both. The carrier break was at 3.55 I believe. I just took my D35 out that I would give you but you're pretty far away. I put 4.11's in it and I just got the 8.8 in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
