What fuel regulator for stroker? - JeepForum.com
post #1 of 2 Old 04-17-2010, 09:24 PM Thread Starter
TEXAIR
What adjustable fuel pressure regulator are you guys running on a 4.6?
I have a 1997 HO engine without the return line. I have installed an E2000 pump on the frame rail near the tank. Now I need a regulator. Which one do you guys prefer? Should I get one with a return line built in?
Also, pics of the fuel pump/regulator would be cool.
89 YJ, 4.6 Stroker, SOA, Waggy 44 and Ford 8.8 w/ARB's. Rollin 35" BFG's. Raptor Lined Body.
TEXAIR is offline
post #2 of 2 Old 04-22-2010, 03:30 PM Thread Starter
TEXAIR
Anyone done this?
TEXAIR is offline
Fuel Bypass Regulator vs. Replacement Fuel Pump gsmith795 YJ Wrangler Technical Forum 3 06-27-2009 05:35 PM
fuel tank fuel regulator bustingear TJ Wrangler Technical Forum 3 02-05-2009 09:01 AM
Do I really need a fuel PSI regulator (weber) bobles YJ Wrangler Technical Forum 18 09-11-2008 07:35 PM
do i need a fuel regulator? dinger YJ Wrangler Technical Forum 0 10-08-2006 04:45 PM
fuel regulator sandman'sjeep YJ Wrangler Technical Forum 1 10-25-2005 02:56 PM
