what ford injectors work with the 2.5L? - Page 2 - JeepForum.com
post #16 of 50 Old 02-15-2009, 03:18 PM
Barrio
I want to do this mod now!!!!!!
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #17 of 50 Old 02-15-2009, 06:05 PM
don2510
I did this mod and it works great. I also got a set of 8 out of a mustang and I only used 4, so I have 4 to let go if anyone would like them.
don2510 is offline
post #18 of 50 Old 02-15-2009, 06:30 PM
ghiradelli777
absolutely a fantastic write-up here!!!! this is a must read for anyone who wants more from their YJ!!!! i am going to use this when i do my injector swap!!!!!
great job!
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #19 of 50 Old 02-15-2009, 07:27 PM
EK91YJ
do you get overall higher horsepower and better mpgs? sounds like a great swap to me!
Red 5.3L LM7 in progress 4 inch Rubicon Express
EK91YJ is offline
post #20 of 50 Old 02-16-2009, 08:40 AM
Dewster196
Don2510, what year mustang did you pull these from and was it a 5.0 or 4.6l motor basically any input on years and model of the fords to check out at the u-pull-it would be great.
Also on the TB from a 4.0 would it be from the same year to bolt to the 2.5 my jeeps a 95 for instance
Dewster196 is offline
post #21 of 50 Old 02-16-2009, 01:13 PM
Barrio
Id be intrested, how much??
Barrio is offline
post #22 of 50 Old 02-16-2009, 03:23 PM
OneCleanYj
I've had my Design III injectors in for a few weeks now and am really happy with the results. Mileage is much better when I have my foot in the throttle, and seems to be just a hair better when I'm easy on it. The power gain was great too, especially in 3rd gear between 50-70. Before it seemed to level off power-wise around 4500, now it climbs up to 6K much better/faster.
For anyone who's interested in this mod, keep in mind that to really benefit from the injectors, they show more improvement with the more mods you've done to accomodate the extra fuel
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #23 of 50 Old 02-16-2009, 05:15 PM
don2510
Dewster, any from 1991 - 2001 5.0 or 4.6 mustang will work. The ones I got where out of a 1996. I also put a 4.0 tb from a 97 jeep on my 93 2.5. Anything after 1995 will have the map sensor on the tb and all you have to do is pull the map sensor off the tb and plug the vac line.
don2510 is offline
post #24 of 50 Old 02-16-2009, 05:52 PM
ghiradelli777
i have a 95 2.5 in my 92 YJ.....will the TB work off of any 4.0L or does it have to be a specific year and do i need the MAP sensor or should i just plug the vacuum line?
post #25 of 50 Old 02-17-2009, 03:42 PM
ghiradelli777
just did the swap and the 4.0l TB swap as well....will let you know how it went after i get the steering stuff hooked up from AGR...
thanks y'all
post #26 of 50 Old 05-02-2009, 06:54 PM
YJInterceptor
I just did this mod this morning thanks to you guys and these threads. I used the phase III injectors from a 94 Town Car and used new o rings. It fired right up and runs much smoother and I feel more response at the petal. The stock injectors were deffinately fouled up. I'm very happy with the results! I also picked up a 4.0 throttle body but forgot to get a gasket for it, so I will swap that out sometime this week. Thanks so much for this information! I was looking at paying over 100 for new stock injectors, and I ended up paying 30 for the TB and 4 injectors from Pull a Part.
YJInterceptor is offline
post #27 of 50 Old 05-02-2009, 08:19 PM
River Ryder
The injectors from a 93'-96' Caprice will work too. 4.3 or 5.7L V8's. I used the 4.3L injectors. They have six spray points and are the same Impedance as stock injectors. Work pretty well for me.
95 Rio Grande 4.0L conversion, T70, Electric Fan, Air Bag suspension, 4 link F/R, 1/2 ton dodge axles and 35x12.5 15. 4 wheel disc brakes. Frame Off restoration in progress. (so many pieces)
1997 Cherokee Sport 2 door 5spd. 4.0L H.O. Cold air Intake, Flow master 40. (Daily Driver) 2.5" lift
River Ryder is offline
post #28 of 50 Old 06-16-2009, 07:18 AM
1993redjeepyj
I just did this mod last night, found in the classifides a guy selling a 4.0 tb and injectors for like 80 bucks. they came in yesterday. and put them both on asap. Great mod, can deffinitly notice some more top end and better throtle response. only bad thing is the mess the injectors make, trying to get the rail off lol. but pther then that everything is just bolt on for both. Amazing
1993 Red jeep wrangler YJ, 2.5L-----SOLD
1997 Blue ford f150, 5.4L----SOLD
1996 Jeep Grand Cherokee 5.2L V8------SOLD
1991 GMC Seirra 5.7L----Project truck
2010 Hyundia Accent BLUE------Current DD
1993redjeepyj is offline
post #29 of 50 Old 12-11-2009, 02:27 PM
4x4fisherman
i have a 1997 tj 2.5l will this mod work on my jeep?
4x4fisherman is offline
post #30 of 50 Old 12-11-2009, 02:50 PM Thread Starter
SteveJcoYJ
it should, i believe its the same fuel rail
but someone should verify
SteveJcoYJ is offline
4.0l injectors work in a 2.5l tjski YJ Wrangler Technical Forum 0 08-02-2009 09:00 PM
Ford injectors Desight III 19LB 1stJeepyj YJ Wrangler Technical Forum 2 03-19-2009 01:40 PM
Ford 24# injectors Fastbeeatch YJ Wrangler Technical Forum 3 02-23-2005 10:59 AM
Ford Fuel Injectors in the 4.0HO?? evilpsych TJ Wrangler Technical Forum 8 08-07-2002 03:42 AM
Ford Fuel Injectors in the 4.0HO?? evilpsych YJ Wrangler Technical Forum 6 08-06-2002 10:15 AM
