what ford injectors work with the 2.5L?
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
i know i've read a few times about people getting good results using the mustang injectors in their 2.5's. I need to get a new set of injectors so i figured this would be a good route. There listed for 87-95 jeep, so i'm guessing the 19lb injectors are gonna work with the stock fuel pump ? and work correctly with the computer after it reconfigures itself?
#2 |
It's Only Rock Rash......
Dont quote me on this but I read on here somewhere that its the 19lb injectors .
but i cant find the thread
'98 TJ Built Sold '95 YJ Built Sold '99 XJ 3" on 31's Build Thread Utah Jeep Crew Member #109 |
#3 | |
I've heard of 19lb Phase III injectors used on a 2.5 with a 4.0 TB before.
From a 91-96 Crown Victoria with 4.6L.
If you're still confused click here to see how I view the forum. |
#4 |
Almost everything you need to know about injectors.
http://4bangerjp.com/forums/index.php?topic=3479.0
-------------------------------------------------- Firefighters Jeep Club http://groups.jeepforum.com/Firefighters_Jeep_Club |
#5 | |
Go Kings Go!
"Warning! The topic or board you are looking for appears to be either missing or off limits to you. Please login below or register an account with 4BangerJP.com."
95 Black YJ *Build Thread* 2.5L, 4.5" RE springs, MORE hoops 1" BL, 35" KM2's, Tube Fenders, Full Cage, D30 Aussie, TeraLow 4:1, HF 8K Winch Herculiner, Warn steering & Gas Tank skids, LED tail lights, TJ corners, Rock Sliders, Ford 8.8, JCR OTK Steering |
#6 |
It works for me. Maybe its because I signed up on the site a while back.
In the beginning there was confusion: Some people seem to think the 2.5L and the 4.0L used the same injectors. They don't. Here's the scoop. From 1991-1995 the 2.5L used the Siemens 53007232. The 4.0L, on the other hand used 33007127 till 1993. Then in 1994 they switched to 53030343. The XJ seems to go along with the YJ Wrangler (the 4.0L Renix used 53003956). To confuse things even more, the 1993 ZJ uses the same injectors (53030343) till 1995. In 1996, some weird things started to happen. Chrysler decided to use the 53030778 universally in both the 2.5L and the 4.0L engines for the XJ Cherokee. The 2.5L TJ, the 4.0L and 5.2L ZJ also used these injectors. The 4.0L on the other hand used 4854181. Then to make things even more complicated in 1997 the XJ and the ZJ switched to 4854181 as well. 1987 -1990 - 4.0L – 53003956 *Cherokee 1991 -1995 - 2.5L - 53007232 1991 -1993 - 4.0L - 33007127 *Wrangler & Cherokee 1993 -1995 - 4.0L – 53030343 *Grand Cherokee 1994 -1995 - 4.0L - 53030343 *source: http://www.crownautomotive.net/catalog/fuel/fuel_injectors.html Now those parts number only help you find the OE part and to see which vehicles used with injectors. What we really need to know is the rate of flow. This seems to be a bit harder to find and isn't listed in the Factory Service Manual. According to some people at http://www.dodgedakotas.com/ and http://www.moparchat.com/ these are the flow rates. 1991-1995 (53007232) - 17.4psi/hr 1991-1995 (33007127 & *53030343) - 21.4psi/hr 1996-2003 (53030778) - 23.2psi/hr *needs confirmation but looks right **source http://www.moparchat.com/ and http://www.dodgedakotas.com/ A thing or two about Injectors: There are a lot of different things to consider when choosing a different injector. First off there is the flow rate. Unless you have calculated your required flow rate you will want to stay near stock. Add too much fuel and you will run rich. Run too small of an injector and you'll run lean. A wide-band O2 sensor with a air/fuel gauge is a good idea when you need to experiment. Several members have noted that when running at higher RPM's the Computer (ECM) leans out fuel. This is really noticeable on a YJ around 4000RPMs. The engine does not want to rev much higher without effort. More on this later. The other consideration when choosing a fuel injector is the spray pattern. The stock fuel injectors have a single jet. This is the hole where the fuel is sprayed out. Some fuel injectors have 2 or more jets to help produce better atomization. You want the fuel to be mixed into the air evenly so a mist be better then a stream. Lets take a look at some Ford Fuel Injectors since those are the popular ones. The one everyone touts is the Ford Design II 'Yellow' 19lbs Fuel Injector. The Injector is a Bosch/Delco and is rated at 19psi/hr. The color helps make a quick ID. Each of Fords fuel injectors are color coded. The Design II's have a plastic upper housing with a metal lower housing. They have a slot on neat the top that holds the retaining clip which holds it to the fuel rail. The Design II Yellows can be found on several different cars but the most common is the Mustang 5.0L. There is a Design III Yellows that is used on Ford Explorers. These are easily spotted by the all plastic design. They do not use a retainer clip and are held in place by the fuel rail itself. It is also worth noting that the plugs for the Jeeps are known as EV-1's. It seems the the Explorer Design III's are one of the few with the older EV-1plug on the newer injector. There are adapters available to use the EV-1 plug on a EV-6 Injector. Both the Yellow Design II and the Design III's use 4 jets. The Design III's are supposed to have better atomization then the Design II's. Getting dirty: Tools required: 11mm Socket 13mm Long Socket Ratchet Ratchet Extension Standard Screwdriver Jar Rags Tape Pen Swapping out the fuel injectors isn't too difficult but can get messy. Start off by disconnecting the negative battery terminal. Make sure there is enough room above the fuel rail. So if the air hose is in the way, remove it. Unclip the throttle cables form the top of the valve cover. Next you will want to disconnect the plugs from the top of the fuel injectors. These are be easy or hard. The trick is to pull straight up. If you pull at an angle they will not release and you risk breaking them. Put some masking tape on them and make where they go if you do not have a Factory Service Manual handy. If there is a pressure regulator on the rail (YJ) disconnect the vacuum line. Next unclip the throttle cable(s). Now that everything is disconnected you can get to work. Start off with the 11mm socket. There are two bolts and a nut that hold the throttle cable bracket on. Move the bracket out of the way. On the other side near the firewall, there is another nut that holds a plug in place. Remove the nut and lift the plug off the stud. Now there are two ways to go about this. One is to remove the fuel rail as one or disconnect the injectors from the rail with it still connected. Both are easy but I think it's easier to take the whole rail off. This gives you enough room to clean the sockets and the rest of the intake if you want. If you decide to take the whole fuel rail off you will want to get a jar ready and place it under the fuel and return connectors at the front of the fuel rail. On the top of the rail is a gray cap. Remove the cap and there is a schrader valve (same used for the tires). This will release the fuel pressure in the rail. It will also leak some fuel. You might want to wrap a rag around it before releasing the pressure. To disconnect the fuel lines you will need a standard screwdriver. There is a white plastic clip that needs to be pulled out while pulling the fuel line in the opposite direction. Once the line comes off, gas will flow out. There is about ¼- ½ cup of gas in there. The injectors are next. Near the top there is a metal clip which holds it to the fuel rail. You'll need a screwdriver to unhook the clip and wiggle the injector out. It won't be easy. The injectors are held in place by the O-rings. If you pull too hard, the O-ring might be lift behind. This is not a problem. Wiggle the injectors out and inspect them. It's probably a good idea to keep track of which injector goes where, in case you ever need to replace them. Now, that all of the injectors are out, it's time to put the new ones in. Before installing the new injectors make sure all of the O-rings are intact. If you're in doubt, replace them. This is not the place to cheap out. To get the injectors in easier, lubricate the O-ring in some gasoline. Don't use too much force otherwise, you risk tearing the O-ring. Once they're in, reverse the steps and you're done. If you can bolt down the fuel rail and it's against the tabs then the injectors are probably seated OK. Once it's all together, it's time to reconnect the battery and try to start it up. Turn the key to ON and wait a second or two. This allows the fuel pump t pressurize the system. It will probably take a second or two to start. If the engine idles fine then you're good. If it seems to be a little rough, you might have a fouled or damaged injector. Check all of the plugs to make sure you haven't forgotten anything. After thoughts: Well according to all of the information above, the 19lbs Fuel Injectors will probably work well on a YJ with some mods. (Test vehicle: 4.0L TB, TBS, Hi-Flow cat, cat-back exhaust, PD Ignition). Otherwise, it might be good to try out the 17lbsDesign III injectors. If you have a TJ, you will probably want to use the 24lbs Injectors. Now on a YJ, I quickly noticed a difference in the exhaust. It sounded a bit more throaty. Around town driving didn't really change. What I did notice was when rev'ing the engine over 4000RPM. With the stock injectors, the engine would feel like there wasn't anymore to give. With the new injectors the engine will easily rev over 5000RPM. This is a clear indication that the ECM leans out the fuel at the higher RPM's. Overall, it was a simple conversion and fairly inexpensive with used injectors. Part Deux: So far I have done this several times over now. It's getting really easy to swap them out and back without making a huge mess. Previously, I installed Ford Design II D5B in the Jeep. When I got to reinstalling them the second time I had some major problems, the engine ran like crap. I believe what happened is that one of the injectors stopped working or it's connector wasn't on all the way although I did check the connectors. So those were removed and the stock ones went back in for the second time. This time around, instead of buying Ford Design II fuel injectors I went ahead and tried some Ford Design III injectors. These are supposed to be superior to the Design II's but at the same pressure, #19. The Design III's are a lot smaller and lighter then the old Design II's because they don't use a metal housing at all. They are all plastic. The other major difference is that there are no retainer clips. The injectors are pressed between the intake and the fuel rail so the use of clips is redundant. The other differences is with the jet end. The jet end is much more exposed. The overall length of the injectors is the same though. I haven't had the Design III's in for very long but they seem to give the same results as the Design II's. The exhaust note is a bit different and the engine seems to freely rev up to 3000rpm which results in a good lump of power. I'm sure reving past 4000rpm is not easier since the engine won't be starving for fuel anymore. Still, I should get a wide-band O2 sensor to get a more accurate reading of the air fuel ratio. In the original install, I forgot to mention how much fuel will come out of the rail. Well, if you don't take the whole rail off, it's not too bad. A small salsa jar fits perfectly on the intake runner for #1 and #2 cylinders. Still some gas is going to drip from manipulating the fuel rail.
#7 |
I just did this, and have had great results. My 2.5 idles better, has better throttle response, and better top end power.
I used the yellow all polymer/plastic body injectors off of a 4.6 town car. They are 19 lb, and called a type III injector. The benefit of these are the 4 hole spray nozzle instead of a 1 hole. This promotes better fuel atomization. I also upgraded to the 4.0 TB at the same time. This is definately worth it if you are thinking about it. |
#8 |
I just sent out a money order this morning to a fellow 4BangerJP member for a set of Design III 19# injectors
I'm also picking up a Rock-It air tube and an open element filter to compliment mine, a 4.0 TB spacer will also be great company for my 4.0 TB ![]() The article Jeffy wrote on 4BJP is a good read for anyone who's interested in this mod. And with the pictures you know which ones to grab. For $33 shipped, I figure they're well worth it I will also try to post pictures and do a short write-up after the install to let JF members know how it works out.
92 YJ. Lifted, rubbered, geared, and more |
#9 |
Junior Member
I have recently done this swap and have had no problems. Yellow top injectors are the ones you're looking for off of most 4.6L equipped fords.
2007 Unlimited JK - Wifey's 99 TJ - Stroked 4.6, 7" lift, Auto, 37x12.50 MT/R w/Kevlar, 4.56 gears 91 YJ - 2.5L, 5spd, stock with Moab wheels - Beach cruiser "Sold to a friend" 2011 Ford F250 - Daily Driver 00 Corvette - NBM, Targa, 6spd, Z51, Magnesium wheels "Garage Queen" 00 Pontiac Trans Am WS6 - H/C 442/434 - Weekend Toy - No Longer with me :( |
#10 |
alrighty then nice, the ford 19lb's are a lot cheaper then oem injectors so that was my main motivation for going with them. I'm glad everyone's had good results. thanks for the info guys
#11 |
to my door a set of 8 for $46 of ebay just now
maybe i'll find another 2.5er guy to sell the other 4 to |
#12 |
Hey you have a PM
91 Wrangler 2.5 - 4" RE standard - 32/11.5/15 BFG All-Terains - 04 F350 Power stroke full Banks kit - 3" lift 35/13/16 Mickey Thompson MTX. |
#13 |
Just to clarify are there any modifications to the electrical connector on the jeep to make them work with the ford injectors.
#14 |
No mods if you use the top feed injectors, which are what we are talking about here.
US Army combat vet Armed Forces Jeeps Member #125 Red Jeep Club Member #251 In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club Click here for 2.5L AX5 to AX15 swap |
#15 |
It seems like better atomization would help increase MPG but this mod probably wouldn't help your MPG would it?
I plan on doing the 4.0 TB to get a little more air in which I've heard improves power and some increase in mpg. The next step would be the injectors, but will it kill my MPG? ![]()
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
