What factory gear ratio do I have? - JeepForum.com
post #1 of 7 Old 03-03-2002, 11:11 AM Thread Starter
JeepMax
Hi,
What is the factory gear ratio of a '95 Wrangler 2.5? Anybody know?
Thx!
JeepMax
'99 WJ Grand Cherokee Laredo
JeepMax is offline
post #2 of 7 Old 03-03-2002, 11:45 AM
JD95YJ
I contacted 4wheel parts about this and I was told that the 2.5's come with 4.10 gears. I have a set of 31X10.50's and 5th gear is pretty tough to get to. They recommend 4.56 gears for me. If you are going to go with larger tires, you may want to see what the best gears are for you. I have to trust those guys because I could not find any numbers for myself. No tags or anything on the rear or differential housing. If I am wrong, sorry.
Anyone else have anything?
jd
JD95YJ is offline
post #3 of 7 Old 03-03-2002, 12:28 PM
95yj-4 cyl
The 5 speeds came with 4:10 gears, but the automatics came with 3:73 gears. You didn't say if your 2.5 had 5 spd or auto. If you are going to run 31" tires (and never anything bigger), I would recommend 4:56 gears (with both trannys---the auto is undergeared from the factory----I know because that's what I presently have). If you think you might go bigger than 31" tires, I would go with the 4:88's. Without any gear change, you can get by, but you'll wear out the clutch faster (if 5 spd), and you'll probably never be able to use 5th gear on the highway. Remember, those 4:10 gears were for 205/75R15 - 215/75R15 tires (about 26-27") from the factory.
95 yj, 4 cyl, auto trans, 4:88 gears, detroit front locker, rear detroit with super 35 kit, short shaft conversion, 4" superlift, 32" superswamper radials
95yj-4 cyl is offline
post #4 of 7 Old 03-04-2002, 09:38 AM Thread Starter
JeepMax
Hi,
Thanks for the replies.
My Jeep is a 5spd and I have been running size 31 tires for as long as I can remember. It never gave me any problems and it shifts like butter - even into 5th. I wanna get 32's or 33's as soon as these tires go out, but I guess I have to get new gears before I do that...
JeepMax is offline
post #5 of 7 Old 03-04-2002, 09:42 AM Thread Starter
JeepMax
BTW - here is a table that shows you the best gear ratios for your Jeeps. It looks like you can go up to 33' with 4.11 ratio.
http://www.gotjeep.net/gearatio.html
Does anybody have experience run bigger that 31 or 32 tires without swapping out gears?
Thanks,
MaxJeep Gear Ratio Table
JeepMax is offline
post #6 of 7 Old 03-04-2002, 10:26 AM
igofshn
Locked @ both ends
igofshn's Avatar
Originally posted by JeepMax:
Hi,
33's will guarranty that you now will have a 4 speed 5th gear will be unusable. Off road performance will stll be very good.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #7 of 7 Old 03-04-2002, 10:42 AM
blazer
I have a 92' 4cyl and 5sp. I also had 410's. I just ordered 488's. I don't think you will be happy with anything higher. Especially if you plan on running 33's.
blazer is offline
Factory gear ratio for Dana35 in 87 YJ? SFM1AE2 YJ Wrangler Technical Forum 14 12-25-2013 08:07 PM
What gear ratio comes factory in a 95 yj with 4cyl and auto tranny? hartswelding YJ Wrangler Technical Forum 5 05-13-2009 08:55 AM
Gear Ratio from Factory? PSYCH0 TJ Wrangler Technical Forum 18 06-28-2008 09:13 AM
Factory Gear Ratio JeepN87 YJ Wrangler Technical Forum 4 03-05-2002 09:28 PM
factory gear ratio on a 93 Yj w/ 4.0 evilpsych YJ Wrangler Technical Forum 4 11-05-2001 11:22 PM
