What exactly does 4 x 4 do on a YJ? - JeepForum.com
post #1 of 72 Old 05-13-2008, 07:34 PM Thread Starter
Urb4nTr0ll
I have 4 x 4 on my YJ, but I'm not sure what it is suppose to do or if it is even necessary.
I have two sticks in my dash, one is a shifter for the transmission and the other is the "shifter" for the 4 x 4 which allows me to put it in 2H or 4H and neutral.
I've only used the 2H and 4H gears a few times and that is just to see what my jeep does. When I click them into gear and then put my Jeep into first gear, my Jeep skids tires with the slightest release of the clutch. In fact, the torque is so strong, that I feel as if my Jeep is going to pop a wheelie. However, I don't go very fast. I have a lot of torque, but very little ability to go fast.
Is this normal of 4 x 4?
Another problem, every now and then, my 4WD light comes on in the dash for no reason and my Jeep's transmission gets into 4WD by itself. It hasn't done it as of yet, but it used to do it when my YJ would generate a lot of heat.
Is this normal? If not, how can I fix it?
I'm mainly a street driver.
Any advice is appreciated, thanks.
Urb4nTr0ll is offline
post #2 of 72 Old 05-13-2008, 07:43 PM
YJames90
YJames90's Avatar
This cant be for real...........
My 2.5 to 4.3 swap thread
YJames90 is offline
post #3 of 72 Old 05-13-2008, 07:46 PM
JpBill
1987 YJ Wrangler
In the process of a 350 swap.
JpBill is offline
post #4 of 72 Old 05-13-2008, 07:47 PM
Jeepinjon
Well, he does have the word "Troll" in is username...
Originally Posted by mean90yj
follow my logic on this one:
the people who say that drive tj's, tj's have round headlights...boobs are round....people who drive tj's are boobs.
Jeepinjon is offline
post #5 of 72 Old 05-13-2008, 07:47 PM
jeepsurf
Is this a dream?
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #6 of 72 Old 05-13-2008, 07:48 PM
pat8942
pat8942's Avatar
Try Googleing four wheel drive and I'm sure you can find more than enough information or just ask some kid to explain it to you.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #7 of 72 Old 05-13-2008, 07:50 PM
JpBill
1987 YJ Wrangler
Read this very carefully:
http://en.wikipedia.org/wiki/Four-wheel_drive
JpBill is offline
post #8 of 72 Old 05-13-2008, 07:50 PM Thread Starter
Urb4nTr0ll
It is for real.
My YJ was given to me, but it has a ton of problems. I'm trying to learn as much as possible about the YJ model so I can address the problems as they surface.
So please post, thank you.
The body is alright, but the engine and everything else that makes it run is unreliable and rusted..
So, on to the 4 x 4 discussion. Thanks.
post #9 of 72 Old 05-13-2008, 07:54 PM
smoke_20
I said the same thing in the "I put Elmers glue in my gas tank thread
I love it when the Troll starts a new thread
Honestly, I don't know who in the world put glue in a Lucas bottle, but it sure suckered me.
Any advice is appreciated, thanks.:thumbsup:
smoke_20 is offline
post #10 of 72 Old 05-13-2008, 07:54 PM Thread Starter
Urb4nTr0ll
So do I use 4 WD on the street or what?
post #11 of 72 Old 05-13-2008, 07:54 PM
jeepsurf
Arent you that "glue in gas tank" guy?
USAF VET
My YJ build thread
jeepsurf is offline
post #12 of 72 Old 05-13-2008, 07:57 PM
JpBill
1987 YJ Wrangler
Alright im trying to be serious here for a second (although its hard to be serious with a question like this)..... just read this
http://jeep.us41.org/4WD/index.html
JpBill is offline
post #13 of 72 Old 05-13-2008, 07:57 PM
jeepin1995
jeepin1995's Avatar
humoring this..... when it has "a ton of torque" you are in 4 low.....(really low transfer case gearing) your 4x4 lever should have 4 spots.....
2WD
4WD hi
neutral
4WD low
4-hi is for slippery conditions where 2wd doesn't cut it. 4-lo is for rough terrain where you need more torque.
oh yea..... unless the streets are covered in snow..... don't use 4wd on the road.
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #14 of 72 Old 05-13-2008, 07:58 PM
Shenandoah
I have the same problem with my machine gun. When I put it in "full auto", it does some strange stuff. When I put it in "single shot", it shoots normally, one bullet for each trigger squeeze.
Turn a wrench, save a tree
Shenandoah is offline
post #15 of 72 Old 05-13-2008, 07:59 PM Thread Starter
Urb4nTr0ll
Thank you. I appreciate that you're watching what I post.
