what engine to use in swap - JeepForum.com
post #1 of 13 Old 10-05-2010, 11:34 PM Thread Starter
95yjjeepster
I am getting ready to do an engine swap in my 1995 yj 4cyl. The problem is which engine to use, 4.0 i6, 4.2 i6 or a v8. Also what transmission to use with them. I recently found a 88 4.2 engine and transmission on cl for 300 and found few v8 around the same. I've got just over 600 to spend and the engine and drive train on my yj to sell. What set up would be the most cost effective and reliable.
Red 95 yj
95yjjeepster is offline
post #2 of 13 Old 10-06-2010, 12:21 AM
MJMPC
With $600 I would try for a 4.0. A 4.2 would be a downgrade.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 13 Old 10-06-2010, 12:36 AM
five-string
Cost effective, reliable and under $600? Only one of your three choices remains, a 4.0L. Don't do the 4.2. It has less hp than your 2.5. I'm ready-ing myself for a 4.0 swap in place of my perfectly running 4.2.
And a v8 swap is talking most or all of your budget in adapters.
Boycott shampoo! Demand the REAL poo!
White Jeep Club #119
☼lllllll☼
five-string is offline
post #4 of 13 Old 10-06-2010, 12:39 AM
hmmhoyhoy
X2, stay away from the 4.2
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline
post #5 of 13 Old 10-06-2010, 12:53 AM
AnonymousD
4.0 will be much easier and cheaper than a V8.
Plus the 4.0 gives you so much room to work on under the hood. I just got my 4.0 YJ and I have been driving a '94 Mustang GT with a 5.0 in it, and I was amazed at how much room there was under the hood of this thing.
AnonymousD is offline
post #6 of 13 Old 10-06-2010, 08:41 AM Thread Starter
95yjjeepster
If I went with the 4.0 what about the engine mounts. I read somewhere that the mounts are different than the 2.5, and also have to replace the fuel lines and CPU and some other stuff. Also was told to not even bother doing 4.0 swap that it would cost three times more to do The swap than to sell my yj and buy one with the engine already installed are these statements true
Red 95 yj
post #7 of 13 Old 10-06-2010, 08:54 AM
1998zj
If you go with the 4.0 you need to get the transmission and transfer case too. The ones on your 2.5 will not work. I agree with the guy that said sell your 2.5 and buy a 4.0 if that is what you want. It will be cheaper.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #8 of 13 Old 10-06-2010, 09:02 AM
parkerm26
why the hell are you going to put a new engine in something your selling? you wont get more than 500 extra for having a 4.0. and plus its not stock(which means most people wont trust your mechenical abilities and therefor won't want to buy it) so you instantly loose at least 50% of potential buyers. it makes no sense. just leave it stock and clean the engine with degreaser and do a full tune up. make it look really good. some people are looking for little 4 bangers these days for better milage anyway. good luck with it
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #9 of 13 Old 10-06-2010, 09:05 AM
five-string
parker, I think you misread his stement. I think he meant selling his original motor and tranny after the swap.
It really depends on what you can find for a donor. I just bought an entire Cherokee with a purrfectly good motor tranny and transfer for $400. I will use all the wiring, computer and motor in my yj plus strip out all the goodies I can find like relays, toggle switches, plugs, bulbs, etc, then I will recover around half my money by selling the rest to the local bone yard. Watch craigslist for a while, be patient and a great deal will come along. Cherokees are a dime a dozen.
I understand you do have to change the frame half of the motor mounts for a 2.5 to 4.0 swap.
Having use of a shop with lots of tools will help make it go easier and less expensive if you can do things like welding and pulling motors on your own.
Read up on the swap in here.
☼lllllll☼
post #10 of 13 Old 10-06-2010, 09:12 AM
Rocky_Cosmark
he isnt selling his yj, he was just saying in the original post that he has $600 plus the sale of his yj drivetrain after he takes it off,but for some advice on the swap, if you want big power but mostly for offroad, get a v-8. Yjs arent great for road use with a v-8 because its terrible gas mileage and the extra weight causes suspension sag over time compared to the i6. But also everyone else is about right saying its a pretty big job to swap from a i6 to 2.5l, and could be cheaper and easier to buy another yj with a 6cyl.
Rocky_Cosmark is offline
post #11 of 13 Old 10-06-2010, 09:23 AM
Pupuslinger
I thought about doing this also when my 4 gets more tired, has about 200k now. Not sure why it would be such a big job if they came with the motors in a different model. Motor mounts and such I can see, but seems like it should be something you can bolt in with the right parts, I will have to do some more research on this for sure. Nice to know the 4.0 is better than the 4.2.
Pupuslinger is offline
post #12 of 13 Old 10-06-2010, 09:27 AM
dodger889
Your checpest way to go is find an running xj or yj that has rear end damage, and pull the engine out of them. Then sell off the good parts then scrap the rest of it. That way you can recoup some of the money spent getting the engine to finish your swap. Like another said if you have shop(garage) setup to do the work yourself. That will save a lot there.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #13 of 13 Old 10-06-2010, 10:47 AM
superj
or, trade me your 4 cylinder wrangler and take my 4.0 cherokee and sell and use money to buy a 4.0 wrangler. then you can cut out all the screwing around and be right where you want to be.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
build , engine swap , transmission swap , YJ
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 04:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 03:08 PM
some ?s on engine swap or trans swap mdf27 YJ Wrangler Technical Forum 3 06-07-2008 10:24 AM
