What donor for a TF727 tranny - JeepForum.com
post #1 of 5 Old 06-21-2010, 06:01 AM Thread Starter
mark12010
I have a 318 magnum form a 98 Ram and I want to put a TF727 behind it. I am not sure what to get it from. Does anyone know what donor vehicle I can get a TF727 4X4 tranny from.
Thanks
Mark
mark12010 is offline
post #2 of 5 Old 06-21-2010, 11:34 AM Thread Starter
mark12010
No one knows?????
post #3 of 5 Old 06-21-2010, 02:42 PM
RedneckYJ
A early to mid 80s Dodge fullsize 4x4 truck would have one. If you needed one for the AMC bellhousing pattern I could help you a lot more.
Robbie
1991 YJ 4.0L
Lots of other goodies!!!!
Take a kid wheeling and let's keep our sport growing.
[]lllllll[]
RedneckYJ is offline
post #4 of 5 Old 06-21-2010, 06:42 PM Thread Starter
mark12010
will that bolt right up to the magnum 318?
post #5 of 5 Old 06-21-2010, 08:32 PM
MoparFreak69
Yep, small block chrysler is the same bellhousing from late 50's onto 2002 when they went to Daimler designed engines.
Only thing you gotta watch out for is make sure it came from behind a 273, 318 or a 340. Most 360's were externally balanced which means the torque converter will not like being put behind a 318.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
Replace TF999 with TF727 dsehl YJ Wrangler Technical Forum 0 03-05-2010 07:20 AM
Tf6 (a-999) To Aw4 Transmission Or Tf6 (a-999) To Tf8 (tf727) TJVZLA TJ Wrangler Technical Forum 3 08-05-2009 09:12 PM
a/c from a donor? Anonymous6915 YJ Wrangler Technical Forum 1 06-29-2009 10:47 AM
will a tf727 direct bolt to my 4.2 pepto YJ Wrangler Technical Forum 10 04-25-2009 02:32 PM
TF727 question learfxr YJ Wrangler Technical Forum 2 11-15-2006 05:44 PM
