What does this switch do? - JeepForum.com
post #1 of 14 Old 03-29-2010, 05:27 PM Thread Starter
linusb
...not a bad punchline but a real question.
The far switch on the right, it appears to be factory based on the connector that is going to it. I don't know what it does. I'm guessing for the rear wiper? (I don't have a hard top anymore...should have tested it before I sold it I guess)
I'm needing to find an ignition switched 12v to send to one of those other switches to run my air compressor. I was hoping one of those wires going to the connector that is hooked up to that last switch would fit the bill, but I can't seem to get any voltage from any of the pins on the connector that is shown connected to that mysterious switch here:
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 14 Old 03-29-2010, 05:30 PM
wrangler76
Rear wiper/defroster for the hard top???
wrangler76 is offline
post #3 of 14 Old 03-29-2010, 05:31 PM
MukYJ
Rear wiper. Should be Off-On-(On) with the 3rd position being a momentary switch for the rear washer.
Did your YJ come with a hard top? I'd have to check the wiring diagram, but it's possible that switch only has power when the hard top is plugged in.
Defroster switch would have a little amber indicator light on it to let you know when it's on:
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
post #4 of 14 Old 03-29-2010, 05:33 PM Thread Starter
linusb
Yes, it did come with a hard top...it had wiper but no defrost. I recently sold it. I figured that's what it was. And dang...yeah there must not be a complete circuit without the top maybe.
Am now ditching A/C in favor of an on board air system. Any suggestions for a suitable 12v wire that I could tap into where I won't risk shorting something importing out??
linusb is offline
post #5 of 14 Old 03-29-2010, 05:41 PM Thread Starter
linusb
Oh, and if anyone can recommend somewhere to get an air/oil separator that's good for up to 150 lbs of pressure, that would be great!
linusb is offline
post #6 of 14 Old 03-29-2010, 05:57 PM
MukYJ
I'll have to look, I forgot where I tapped power for my compressor. You should be able to tap into any ignition switched power supply for the compressor switch, as long as it's only powering a relay.
As for a coalescing filter, the best price I found was part number 1-816-8923M from KBC Tools. It's a CoilHose filter, the same one sold by Kilby but for $45 less.
KBC Tools & Machinery /USA
I had heard bad things about the plastic bowls melting in the engine compartment, so I went with the metal bowl good up to 250 PSI.
MukYJ is offline
post #7 of 14 Old 03-29-2010, 05:59 PM
Sleuthhound
That's a classic "famous last words" for a good D&D session...
PC 1: "Hey, what's this switch do?
PC 2: "No, dont!" *
*click*
*enter 10d6 fall damage*
Sleuthhound is offline
post #8 of 14 Old 03-29-2010, 06:22 PM
kb2ztx
Mine is in the same spot, but is the fog light switch. It also has an on off momentarty positions. When I flip it to on (with the headlights on) it lights up, and now even lights my Hella Fog Lights
kb2ztx is offline
post #9 of 14 Old 03-29-2010, 07:45 PM Thread Starter
linusb
Ok, I found a good wire to power it from. It's coming off an unused connector near the cigarette lighter. Have no idea what it was intended to go to. I'll post up a pic tomorrow to see if you dash gurus can tell me if it poses any danger to use it.
linusb is offline
post #10 of 14 Old 03-29-2010, 08:02 PM
Nicho
[quote=MukYJ;9183345][COLOR=Navy]Rear wiper. Should be Off-On-(On) with the 3rd position being a momentary switch for the rear washer.
x2- its open.
Nicho is offline
post #11 of 14 Old 03-31-2010, 07:00 PM Thread Starter
linusb
I found a filter/regulator for sale local. I'm wondering if having a regulator on the filter would interfere with the pressure sensor switch in any way?...the switch I have is a 110-150. I'm thinking it would be ok and that the regulator wouldn't flow air into the system until the pressure behind it exceeds that which the regulator is set for.
linusb is offline
post #12 of 14 Old 04-01-2010, 10:14 AM
timatoe
timatoe's Avatar
Originally Posted by MukYJ View Post
Sorry for the quick hijack,,,,,
Where'd you get those switches, (the ARB style contura onese)? I'm trying to find some that can be labeled.
timatoe is offline
post #13 of 14 Old 04-01-2010, 10:59 AM
sparkeep
Go to OTRATTW.com... good price and great service. Plus the switches are a very good design (made by Carling Tech).
OTRATTW
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #14 of 14 Old 04-01-2010, 11:10 AM
timatoe
timatoe's Avatar
OTRATTW
Thanks.
timatoe is offline
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 02:11 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Having problems with lights. Does the dimmer switch run through the headlight switch? spshultz YJ Wrangler Technical Forum 2 10-25-2009 06:43 AM
Replacing fog light stalk switch with dash mounted switch? Imped TJ Wrangler Technical Forum 7 08-31-2008 12:58 PM
Convert vacuum switch t-case to electrical switch halfline YJ Wrangler Technical Forum 8 09-11-2004 06:24 AM
