What does the computer do after a nutter? - JeepForum.com
post #1 of 18 Old 11-22-2011, 06:08 PM Thread Starter
bluedaffy
Exactly what the title reads... After the nutter can you just throw your computer out the window? What purpose(s) does it still serve?
bluedaffy is offline
post #2 of 18 Old 11-22-2011, 06:42 PM
HARLEYX2
1987 YJ Wrangler
Trash
HARLEYX2 is offline
post #3 of 18 Old 11-22-2011, 06:57 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Ebay fodder
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #4 of 18 Old 11-22-2011, 07:30 PM
carnuck
1984 J-Series Truck
Anchor weight
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 18 Old 11-22-2011, 08:06 PM
Mark05059
frisbee?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 18 Old 11-22-2011, 08:26 PM
Jax89Jeeper
Target practice... Priceless.
Jax89Jeeper is offline
post #7 of 18 Old 11-22-2011, 09:12 PM
Alabamaranger
Ebay - least $25 to $50
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #8 of 18 Old 11-22-2011, 09:20 PM Thread Starter
bluedaffy
Sweet! It's currently residing by my shifter, can I literally get rid of the whole thing?
post #9 of 18 Old 11-23-2011, 07:01 AM
waif69
1987 YJ Wrangler
Yup, and the wiring associated with it.
waif69 is offline
post #10 of 18 Old 11-23-2011, 07:10 AM
superj
where is it normally hidden? i did he nutter on mine but never dug out the computer. i will undo mine too.
if its hidden well, i bet you could put a small amp in its place and run some higher power speakers off it so you don;t have ot worry about someone stealing it
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #11 of 18 Old 11-23-2011, 07:19 AM
jeep16
its hiddin by the blower motor on the passenger side of the firewall. you will have to remove the dash to get it out.
jeep16 is offline
post #12 of 18 Old 11-23-2011, 07:44 AM
Berniebikes
don't have to take out the dash, only the glove box. It is behind the golve box held on by a bracket attached to the firewall. You can remove the computer, then any wire which is connected to it, and any sensor connected to the wires.
Berniebikes is offline
post #13 of 18 Old 11-23-2011, 08:10 AM
waif69
1987 YJ Wrangler
It is true. However, it is a bear to get out, don't be surprised if you wind up with some blood on your fingers, but it is still easier than taking the whole dash apart.
waif69 is offline
post #14 of 18 Old 11-23-2011, 12:15 PM
superj
sweet!!
but this dash doesn't look horribly hard to remove. just to keep some conversation going. it seems very easy to take out as so much of its exposed.
bmw put the ecu on the e30 series in the same place. drop the glove box and undo the plastic cover and then ecu was right there held on by four 10mm bolts.
superj is offline
post #15 of 18 Old 11-23-2011, 02:28 PM
Berniebikes
The dash may be harder to remove than you think. You have to disconnect the rollbar and drop the windshield, then remove a bunch of screws from plastic which is subject to break. Pray that your windshield hinges aren't rusted. Once you have done that you have a few torx on the front and have to get all the plastic across the front and your radio, gauges, heater controls, speakers speedometer and tach all disconnected. You also have to pull the steering wheel. Once it is all loose you have to wiggle it out over your steering column. Not quite as easy as the few nuts on the back of the glove box, but your call. Here's a pretty good thread
http://www.jeepforum.com/forum/f12/a...93/index2.html
computer , nutter , nutter bypass
Quick Nutter Question!! Calling All Nutter Experts WhyJayPA YJ Wrangler Technical Forum 6 02-29-2012 09:35 AM
Do I have to Nutter? jefnjan YJ Wrangler Technical Forum 1 08-20-2009 11:51 AM
nutter necessary? madmax79 YJ Wrangler Technical Forum 2 12-17-2007 05:20 PM
Pulling computer after Weber and Nutter COJAM YJ Wrangler Technical Forum 6 02-03-2005 12:06 PM
To nutter or not to nutter rrclimber YJ Wrangler Technical Forum 3 08-28-2003 06:59 AM
