What do you guys think of this locker set-up? - JeepForum.com
post #1 of 4 Old 03-04-2002, 05:41 PM Thread Starter
Missin44
Looks like I will be setting up my lockers sooner than I thought. See my other posts if wondering why.
'92 YJ 5 speed, 6 cyl., 4:10 diff, 31" tires(may go to 32's some day)
Kicking around the idea of OX Locker(Maybe ARB) up front with True Trac Limited slip in rear. The main reason I have to do it now, front ring and pinion must be replaced.
Would like to have street manners as close to stock as possible or better. Really looking for the best combination of street and off-road use. What do you guys think? Any other options I should look at?
'92 YJ, 4.0L, 5 spd, OX Locked front, 4:10 gears, BDS 3.5" lift, reverse shackles, Ford 8.8 Limited-slip rear, York OBA, JB Conversions SYE Kit, CV driveshft, Centerforce II clutch, Big Daddy Step Rock Rails, Skid Row Top Prop, Big Daddy OffRoad Front Bumper, Yokahoma Geolander 32's, Rokmen Riddler differential cover
Missin44 is offline
post #2 of 4 Old 03-05-2002, 12:09 AM
kidwired
kidwired's Avatar
use the ox in the rear and the l/s in the front. or better yet do ox/ox or arb/arb
you will be sorry having the l/s in the rear instead of a true locker when you get in the touch sections.
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #3 of 4 Old 03-05-2002, 08:23 AM
bobznew
True dat. Full locker should be in the REAR, IMHO.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #4 of 4 Old 03-05-2002, 08:40 AM
RodeoRob
RodeoRob's Avatar
I agree with the selectable in the front... if you've ever wheeled on hard surface's such as Moab slickrock with an autolocking (lockright) front, you'll definitely know what i mean... damn thing never unlocks! Sure you can always get out and unlock a hub (thats if you have hub locks) to make turns, but this is a PITA. If I was to buy only one selectable locker, i'd put it in the front.
I currently run a OX front and Detriot rear in my Isuzu. I used to run lockright front and no-slip rear and choose to go with the selectable front for the reason above.
IMO, autolockers (lockright, noslip, detriot) aren't that bad in the rear, even for a daily driver (which my rig is).
-Rob
EDIT: If you want the best of both worlds, onroad and off, and price isn't a consideration, I vote for OX/OX or ARB/ARB. You can't beat selectability.
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
How hard in your guys opinion is it to install an aussie locker in the front Goobersbro YJ Wrangler Technical Forum 51 06-12-2009 04:05 PM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Ox Locker guys Prowler YJ Wrangler Technical Forum 3 03-25-2007 03:53 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
