what do you guys think is the best oil filter for the I6? - Page 2 - JeepForum.com
post #16 of 22 Old 06-09-2010, 03:08 AM Thread Starter
vicker
thnx brewer but what brand is good oil? i always used pennzoil.
vicker is offline
post #17 of 22 Old 06-09-2010, 06:58 AM
clush
I used Fram for 190K and it protected my engine just fine. But they are not made as well as others and I was also younger and dumber than I am now. Just changing the oil routinely was the important thing I guess. I use nothing but WIX on all my stuff now, the make the best filter by far IMO.
clush is offline
post #18 of 22 Old 06-09-2010, 08:21 AM
dropped74
I like wix filters and run valvoline 10-40 max life oil!
dropped74 is offline
post #19 of 22 Old 06-09-2010, 10:54 AM
HighRoller02TJ
Originally Posted by 4LarXedo4 View Post
Mopar if i can find it, otherwise i wait till advanced autoparts does the $16.99 oil change special in which case is 5qts of castrol and a purolater
mopar at walmart $5
HighRoller02TJ is offline
post #20 of 22 Old 06-09-2010, 10:57 AM
HighRoller02TJ
Originally Posted by SonofSam02 View Post
the purolator plus(gold box) at advance is the best bang for the buck ive found. Has the highest multi-pass efficency (around 99%, which is the primary function of a filter) of most of the oil filters and is around 7 dollars. The Fram, K&N and Mobil1 have lower efficency as does the mopar( if you don't believe me, read the boxes). The new bosch distance plus filters have a high efficency and are supposed to hold more dirt.
dont believeverything you read
post #21 of 22 Old 06-09-2010, 09:41 PM
jeeepguy
jeeepguy's Avatar
Napa Gold until Royal Purple came out with theirs.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #22 of 22 Old 06-10-2010, 04:19 AM
MWT
you guys are correct to go with the mopar filter . a few years ago we cut open all leading "off" brand filters,we work at a jeep dealership,and you wouldn"t believe the difference. the mopar filter is far superior to any filter we cut open!! good luck
MWT is offline
synthetic oil filter vs regular oil filter MacK JK Wrangler Technical Forum 2 10-31-2009 10:09 PM
Air Filter Oil Filter whats the difference? LlamaJeep YJ Wrangler Technical Forum 9 03-15-2008 10:52 AM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 04:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 09:02 PM
stock filter vs. K&N air filter 90yjwrangler YJ Wrangler Technical Forum 8 12-01-2004 05:49 PM
