what do you guys think is the best oil filter for the I6? - JeepForum.com
post #1 of 22 Old 06-08-2010, 07:51 PM Thread Starter
vicker
i have a fram on there now(came with the car) but everyone seems to agree fram is cheap crap. so i was looking in to using a bosch or spend a bit more money on a K & N oil filter? whats been your experience?
Thnx
vicker is offline
post #2 of 22 Old 06-08-2010, 08:01 PM
HighRoller02TJ
I use Mopar filter
HighRoller02TJ is offline
post #3 of 22 Old 06-08-2010, 08:05 PM
4LarXedo4
Mopar if i can find it, otherwise i wait till advanced autoparts does the $16.99 oil change special in which case is 5qts of castrol and a purolater
4LarXedo4 is offline
post #4 of 22 Old 06-08-2010, 08:13 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
On my new car and van I run mopar for the van or NAPA GOLD. On the jeeps, I was running fram till I turned over a new leaf and discovered that mopars were better. Otherwise, yet again, NAPA GOLD.
See a theme here??
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 22 Old 06-08-2010, 08:55 PM
MoparFreak69
Mopar is always better
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #6 of 22 Old 06-08-2010, 08:56 PM
brewer
I`ve usually been partial to napa gold but I`ve actually cut open some of the various brands on the market and found very little in separating them from each other. I will admit the cheaper ones tended to use paper that was not as evenly woven / folded for proper filtration but about $6 for a filter is going to get you a decent safe bet. Regardless, the filter is only as good as the oil it is trying to filter out, so if you use cheap oil... then it doesn`t matter how good a filter you have. That said, if you use really good oil, why would you need a really good filter? how is debris getting in?
Beauty is but a lightswitch away :D
brewer is offline
post #7 of 22 Old 06-08-2010, 09:02 PM
Mark455SD
1961 CJ5
Where are you guys getting the Mopar filter from?
Mark455SD is offline
post #8 of 22 Old 06-08-2010, 09:03 PM
brewer
mopar is a chrysler / jeep brand name. therefore, any dealership
brewer is offline
post #9 of 22 Old 06-08-2010, 09:06 PM
timatoe
timatoe's Avatar
WIX or Napa Gold (which I think WIX makes)
timatoe is offline
post #10 of 22 Old 06-08-2010, 09:07 PM
Mark455SD
1961 CJ5
How much is a filter at the dealership..I have a broken roll bar bolt and went to the dealer and they want 49.99 for the bolt
post #11 of 22 Old 06-08-2010, 09:08 PM
hondacr21
hondacr21's Avatar
Mopar
1995 Sahara, Borla header, Rear stretch 103" wheelbase, Sniper Fab Comp Corners with 3" flare, SOA with .75" SL, 2 1/2" Rancho lift on 37"s MTR's on 15x8 eagle alloys. JB4x4 steering bracket, M.O.R.E., 8.8 with limited slip and 4.10's, AA SYE, modified XJ front driveshaft, Superwinch EPi 9.0, homemade boatsides, 6 point cage.
hondacr21 is offline
post #12 of 22 Old 06-08-2010, 09:09 PM
hondacr21
hondacr21's Avatar
advanced auto parts has the Mopar filter you need they are around 6$ around here
post #13 of 22 Old 06-08-2010, 09:33 PM
SonofSam02
the purolator plus(gold box) at advance is the best bang for the buck ive found. Has the highest multi-pass efficency (around 99%, which is the primary function of a filter) of most of the oil filters and is around 7 dollars. The Fram, K&N and Mobil1 have lower efficency as does the mopar( if you don't believe me, read the boxes). The new bosch distance plus filters have a high efficency and are supposed to hold more dirt.
SonofSam02 is offline
post #14 of 22 Old 06-08-2010, 10:47 PM
jeeptim
I am a manager at advance, and i agree on the mopar...the purolater pure is a good choice, filters 99.9% of contaminents. The new bosch premium filters also do this but they hold 300% more dirt than the pure one and have a higher burst pressure 600psi I believe, more comprable to a k&n or royal purple.
1989 Islander 4.2 Automatic. RC 2.5" lift. 265/75/16
jeeptim is offline
post #15 of 22 Old 06-08-2010, 11:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The stock Mopar MO 090 oil filter can be found at WalMart for $3-$4 IIRC.
FWIW, I use the Motorcraft FL-1A for extra capacity.
Covered in detail here......
http://www.jeepforum.com/forum/f12/b...change-865490/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
synthetic oil filter vs regular oil filter MacK JK Wrangler Technical Forum 2 10-31-2009 10:09 PM
Air Filter Oil Filter whats the difference? LlamaJeep YJ Wrangler Technical Forum 9 03-15-2008 10:52 AM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 04:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 09:02 PM
stock filter vs. K&N air filter 90yjwrangler YJ Wrangler Technical Forum 8 12-01-2004 05:49 PM
