What do y'all think about Sound Bars? - JeepForum.com
post #1 of 13 Old 03-18-2002, 11:31 PM Thread Starter
Wexxon2000
My Jeep has two tweeters in the dash and nuthin else...except for a cd player with the face ripped out. I need to eaither replace all the speakers, or I can just get a sound bar. I was wondering if the sound quality is good enough to go that route.
thanks to all who reply
'87 Black YJ Wrangler
3" RC Suspension Lift
33/12.5/R15 Mickey Thompson MTX
Wexxon2000 is offline
post #2 of 13 Old 03-19-2002, 09:00 AM
Big92Jeep
JC whitney makes a 6 speaker bar! It's then only one I would consider.
~RýcK
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #3 of 13 Old 03-19-2002, 10:15 AM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
I'm in the same boat you are man. I tell ya, all the soundbars I see in the catologs, they don't go into depth on the speaker specs. And the speakers don't look so hot anyways. How much can a 6" speaker really put out?! However, on ebay, they have a custom soundbar for $100!! It has no speakers, but thats better so you can pick what you want in there, and they are designed to hold 6x9's those can really pack a punch. I want a semi-deep tone over the stock 4x6's I got now, but I dont wanna go crazy with subs and amps cuz its a soft top and I'd rather it not be ripped off. My plan is to replace the receiver with a decent CD receiver. Replace the 4x6's and get that sound bar with some good 6x9's. Thats all I really need.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #4 of 13 Old 03-19-2002, 10:27 AM
GREGDOG95YJ
GREGDOG95YJ's Avatar
be careful how you set up your sound bar because if you try to run a multiple speaker setup (dash, soundbar, & sound wedges) all you will here is the one speaker right over your head. the other speakers will seem useless. if all you are going to use is the speaker bar it doesn't matter. good luck figuring out your setup.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #5 of 13 Old 03-19-2002, 10:54 AM
KYgreenYJ
I would get the cheap plastic soundbar from Rosser and just junk the speakers after you blow them out(they are pretty crappy poly audio speakers i think) and replace them with some better ones that can handle all the power ur head unit has. This sound bar is easy to add to because the plastic is pretty easy to work with.
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #6 of 13 Old 03-19-2002, 11:25 AM
MusicMaverick
2014 JK Wrangler
But the bar on ebay I told you about is even cheaper than the plastic one you mentioned. For only $100. As for wiring:
This is only true if you have a 2 speaker setup from your receiver. A decent receiver will have 4 outputs, 2 fronts and 2 backs. SO one for each dash, and one for each 6x9 in the soundbar, and dont bother with anything else like wedges or whatever.
Currently: '14 JKU
post #7 of 13 Old 03-19-2002, 01:57 PM
vandall
I'm installing two 10" subs & need to build a box for behind the back seat. The subs I bought require the following internal air space:
I went out and bought a pair of 6x9 speaker boxes, a pair of sony 6x9 X-plod speakers and a 300watt amp and mounted the boxes on the rear wheel wel. I have great sound and it cost me $200. I got everything at best buy.
My fried bought a sound bar and his head hits it because of the way it is mounted between the bars.
89 wrangler, 4.2 auto 33"sidewinders, 3 in body lift,
vandall is offline
post #8 of 13 Old 03-19-2002, 05:20 PM
MusicMaverick
2014 JK Wrangler
Well see here's MY prob with that. I'm a drummer. So when I play a gig, I need ALL that cargo space. I have to take out the rear seat and I used EVERY square foot of space back there. I can't afford to have speakers around like that. Otherwise I would tho.
Currently: '14 JKU
post #9 of 13 Old 03-19-2002, 05:44 PM
Patton
Another advantage if your bald headed it keeps some of the sun of your head and neck.
I,m allready too red neck
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
post #10 of 13 Old 03-22-2002, 03:38 AM
highway jeeper
I needed more speakers but did not like the idea of the speakers directly on top of my head so I went with the new Centra Pod speakers from 4WD. They sit on the hump in front on the floor. They work really great and have plenty of good volume.
87 YJ, 258, 2 1/2 Procomp, 1 inch body lift, webber carb, juicebox
highway jeeper is offline
post #11 of 13 Old 03-22-2002, 07:22 AM
black yj
i want to replace my stock dash speakers, are they 4x6s? and what is a good replacement, i was told i had to be carful because there was no room with the stock set up.
black yj is offline
post #12 of 13 Old 03-22-2002, 09:09 AM
benci007
hey i have a 2 speaker sound bar and it sounds fine, but i get absolutely NO bass. So if thats not important, go for it. But then, you might need subs. The alternative would be to get a box, but that would be expensive. Good luck and happy hunting.
'99 TJ, 6" total lift, 33x12.5's BFG M/T's, banks exhaust, k&N intake, and the list continues
benci007 is offline
post #13 of 13 Old 03-22-2002, 09:28 AM
bigblueyj
off topic and being moved to radios have any questions email me txmudboy83@hotmail.com
bigblueyj is offline
sound bars canesqb3 YJ Wrangler Technical Forum 12 10-07-2013 05:11 PM
2 sound bars? speepdaedeesi YJ Wrangler Technical Forum 3 05-22-2009 11:09 AM
Sound bar wiring in roll bars? Hesher420 TJ Wrangler Technical Forum 3 11-21-2008 05:44 PM
Sound Bars disarm6565 YJ Wrangler Technical Forum 4 09-14-2004 10:32 AM
sound bars ryan14 YJ Wrangler Technical Forum 4 02-28-2002 04:53 AM
