What is the difference between a '87 258 and a '86 258 - JeepForum.com
post #1 of 13 Old 04-03-2002, 07:28 PM Thread Starter
Plink
Plink's Avatar
It seems like my 87 has a 86 258 in it. Can anyone tell me the difference between the two? Thanks
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #2 of 13 Old 04-03-2002, 07:57 PM
johny1i
johny1i's Avatar
One easy way may be the valve cover--I know a lot of CJ's (if not all) came with plastic ones. My 1990 came with an aluminum one, a revision that I believe began with the 1987 Wrangler. Also, that CJ valve cover only has approximately 7 bolts that hold it on while mine has about twice that many.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #3 of 13 Old 04-04-2002, 06:02 AM Thread Starter
Plink
Plink's Avatar
Thanks I'll take a look today.
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #4 of 13 Old 04-04-2002, 06:56 AM Thread Starter
Plink
Plink's Avatar
I looked and there were definetly more then 7 bolts. The reason I'm asking is because I got an 87 and it was much wider and the threads don't match the one I took off. I bought a 86 CJ 258 oil filter and it worked. I just want to make sure I buy the right parts for my Jeep. If the oil filters are that different then I really need to make sure.
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #5 of 13 Old 04-04-2002, 09:48 AM
johny1i
johny1i's Avatar
Try to get some input from someone with an '87. Something must be up for it to have that oil filter situation, and my valve cover suggestion was very non-technical. My brother has an '85, so I can only compare that to my '90.
johny1i is offline
post #6 of 13 Old 04-04-2002, 11:23 AM
4wheeler4CJ
4wheeler4CJ's Avatar
The basic engine block should be the same. I don't know what minor changes there could be. I would imagine that the oil filter is the same. Most changes over the years occurred on the top ends (intake/exhaust/aircleaner/vbalve cover, etc.)
If you can get the engine ID #, you can cross-check it with a service manual to find the year, etc.
I suspect you have an '87 motor, and they gave you the wrong part. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #7 of 13 Old 04-04-2002, 11:23 AM Thread Starter
Plink
Plink's Avatar
Roger that! With people swapping heads and blocks no telling what you're going to get. I bought my YJ for $50 and a case of Sam Adams! For that price I'll take just about anything!
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #8 of 13 Old 04-04-2002, 12:31 PM
4wheeler4CJ
Good frickin deal! Gotta love a deal like that!
post #9 of 13 Old 04-04-2002, 12:59 PM Thread Starter
Plink
Plink's Avatar
Hey 4wheeler4CJ do you have the crank pulley off the 258??? The one I have is eating fan belts.
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #10 of 13 Old 04-04-2002, 01:47 PM
4wheel4fun
It really depends on when your 87 was manufactured. My 87 was actually built in late 86' for the 87' year, so it came with a plastic valve cover. The engine core is really the same. The critical changes came in the trans and Tcase.
4wheel4fun is offline
post #11 of 13 Old 04-04-2002, 02:03 PM Thread Starter
Plink
Plink's Avatar
Mine has the Aluminum valve cover. I found some vacuum leaks this morning. I replaced the old hose and my idle is around 800rpm. It sounds pretty good but it still coughs alittle. I'm hopeing that will stop when the year old gas runs out! I mixed in some 97 oct. Anyone have any tips on cheap engine mods and lifts. I'm thinking about doing a 2" block lift. I have no idea kind of lift I should do. I don't plan on doing heavy off roading but would like to do a little bit this summer. Thanks
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #12 of 13 Old 04-05-2002, 07:55 AM
4wheeler4CJ
I have a '76 232 Block (same as the 258), I'll have to look to see if I still have the pulley, I'm almost positive, I have every part for the complete engine, I disassembled it when i took it out of the Jeep, so i could sell the components (engine wasn't running when I bought the Jeep, had sat a while). Email me to remind me to look, LOL ericnmish@yahoo.com <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #13 of 13 Old 04-05-2002, 02:44 PM Thread Starter
Plink
Plink's Avatar
Already did....let me know.
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
what is the difference? Canfourjeep YJ Wrangler Technical Forum 2 02-14-2008 02:08 PM
Is their a difference between 98 and 06 Tjs? JoshBowers TJ Wrangler Technical Forum 6 08-03-2006 11:31 PM
how to tell the difference green_jeep YJ Wrangler Technical Forum 12 03-23-2006 07:00 PM
Difference between 97 & 99 dali555 TJ Wrangler Technical Forum 6 09-14-2005 11:49 PM
Difference between 00,01,02 TJs quzur TJ Wrangler Technical Forum 8 10-11-2004 08:56 PM
