What did i miss on a nutter job - JeepForum.com
post #1 of 13 Old 08-08-2013, 10:15 PM Thread Starter
rogerv
I was helping a friend nutter his 90. Ran the wires, added the ground from the dist. to the batt, he even had a dist with the 18r/13r slots. I switched it to the 18r.
Well after it was all said done- no start. I confirmed spark by pulling a plug, double checked I was at TDC on the compression stroke (#1). Had to reset the plug wires on the cap since I flipped the plate, went back and checked TDC for the 3rd time, still no start.
I'm at a loss here guys, did I over look something simple ?
If it's not broke- modify it, so it won't break
rogerv is offline
post #2 of 13 Old 08-09-2013, 09:48 AM
jbrown73
And all you performed was the Nutter? Does it attempt to start then stall or does it just keep turning over?
"The Constitution is not an instrument for the government to restrain the people, it is an instrument for the people to restrain the government....." - Patrick Henry
Originally Posted by Rproject View Post
The only thing I can say is to close your eyes. Seriously. If you close your eyes and pay attention to your finger tips, you'll be able to feel the nuts better and manipulate them easier.
jbrown73 is offline
post #3 of 13 Old 08-09-2013, 10:23 AM
Old4X
1990 CJ7
Did you run a new twisted pair from the dizzy to the ICM? Check continuity on wires and connections?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 13 Old 08-09-2013, 11:42 AM Thread Starter
rogerv
@ jbrown, yes just the nutter, switched the dist plate from the 13r slot to the 18r slot
@ old 4x, yes we ran all new wire for everything.
Update- I switched it back to stock configuration, fired right up. The only thing I can come up with is a bad connection some where. I did however find some collapsed vac hoses and the carb (weber 36) has fuel dripping into the intake. I called the owner and told him my findings. He's gonna get that all fixed first and then we will do it again.
rogerv is offline
post #5 of 13 Old 08-09-2013, 12:15 PM
Old4X
1990 CJ7
The distributor pickup signal is very weak and prone to signal reflection from improper connection and/or wire length.
When I did mine, I added extra length so as to relocate the ICM. It would not run or ran very poorly. My connections were fine, wire was fine. Cut the extra length out and haven't had another problem for several years now.
The AC signal sent from the dizzy is around .5 volts, no room for error.
Not saying this is your problem, but I ran into it.
Old4X is offline
post #6 of 13 Old 08-09-2013, 12:31 PM Thread Starter
rogerv
I thought about that last night and cut about 10" of twisted wire out, maybe that wasn't enough. I'll try it all again after the carb gets rebuilt. I'm gonna change out the bad vacume lines today so hopefully it will help a little.
rogerv is offline
post #7 of 13 Old 08-10-2013, 07:39 AM
90DesertTanYJ
I also added a bit of extra twisted wires to mine for an ICM relocate as well but didnt experience any issues. I also replaced the plug at the distributor with a 3 prong weatherpack plug because my OEM plug was green inside and out. I soldered all splices and heat shrunk them. If your using crimp splices I would definitely replace those. The distributor ground runs all the way from the ICM you may want to ground it to the block closer to the dizzy.
You said you put it back to OEM config and it runs? What exactly is different? Connectors? Splicing? Just the added wire? Does it run Nuttered in the 13R position?
One step at a time, figure out where the loose connection is.
Old ICMs also get squirrelly but since its about $60-70 I would not just throw a new one in. Probly not your issue but it was my main issue after going thru and doing the Nutter and other ignition electrical repairs chasing my intermittent shut down and random poor performance. When I relocated my ICM to the firewall I discovered something was loose inside my ICM. I would smack the ICM with a screwdriver handle and it would almost shut down.
Good luck, keep us posted.
90DesertTanYJ is offline
post #8 of 13 Old 08-10-2013, 07:50 AM
Old4X
1990 CJ7
"Old ICMs also get squirrelly"
True words
Old4X is offline
post #9 of 13 Old 08-10-2013, 09:54 AM Thread Starter
rogerv
True words
Old4x- the exact reason why our rides run a GM control module
rogerv is offline
post #10 of 13 Old 08-10-2013, 12:26 PM
Old4X
1990 CJ7
True words
Old4X is offline
post #11 of 13 Old 08-10-2013, 12:51 PM
Old4X
1990 CJ7
Did you double check you didn't cross the wires? Although they are AC, the phase is different if crossed. It will still work, but needs a very large physical adjustment at the pickup, IIRC.
Old4X is offline
post #12 of 13 Old 08-10-2013, 01:01 PM Thread Starter
rogerv
Yes sir, made absolutely sure purple to purple and orange to orange.
I talked with another local keeper this morning and his first question was " did you cross the wires? ". No, then he asked about the connections. When we go to do this again ill make the twisted pair shorter, see if that makes a difference.
Won't be for about 3 weeks though, being I have a week long school I have to go to and then my normal 2 week work schedule.
We'll get, with the help from this forum anything possible !
rogerv is offline
post #13 of 13 Old 08-13-2013, 09:05 PM
smimik
I went through the same exact issue when I Nuttered mine. I replaced the ICM and it fired right up. It fired up when I un-nuttered it trying to trouble shoot it. It didn't make since as to why but it has been running like a top after installing the new ICM.
smimik is offline
