What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? - JeepForum.com
post #1 of 5 Old 08-22-2010, 09:37 PM Thread Starter
BigDeaner
1987 YJ Wrangler
My yj hardtop took a tree along where the door would close, buggered it up pretty bad. Attempted to repair the fiberglass once, but only lasted a cpl months cause of the door always hitting the same location. I already have a cj top laying around that i'm going to use, so I'm not into dumping any more money into my broken one. I was thinking of trying to re-use either from the windshield to center roll bar, or possible further back, just using basically the roof section. The front would attach stock, and then I thought mayne i could rig up some u-bolts to support the rear end. Just wondering if anyone else has bother to try and make some use out of a broken hardtop besideas actually fixing it. Any ideas or suggestions would be awesome, thanks in advance
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
BigDeaner is offline
post #2 of 5 Old 08-25-2010, 09:35 PM
eternal_dragon
If the front half is completly broken off;
See if you can mount it on the rear to make a hard tonneau cover/cap, may need to remove rollbars to make rough in cutout lines for the rollbars. This would be really handy for storage. To secure just drill-out some holes above mounting holes, get longer bolts and rubber washers(plumbing section) and use the same rear mounting nuts.
send me a pic if you do it!
good luck
eternal_dragon is offline
post #3 of 5 Old 08-25-2010, 10:32 PM
Mark455SD
1961 CJ5
how bout a coffee table
Mark455SD is offline
post #4 of 5 Old 08-25-2010, 11:02 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Scrambler style hard top?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 5 Old 08-26-2010, 12:00 AM Thread Starter
BigDeaner
1987 YJ Wrangler
i like the idea of the scrambler style top, although i can't go that route since mine is cracked along the edge where the door closes against. The tonneau cover idea could work, but with the rollbars there it would probably be hard to work with/around. The coffee table idea, would be sweet if, i was single,lol.
1987 JEEP YJ LAREDO
NP231,AX15,D30,D35
"Adjustable" Safari Bikini Opinions jbodenhamer TJ Wrangler Technical Forum 8 05-31-2010 03:00 PM
Front driveshaft- Ring clip "lip" broken. LGriffith TJ Wrangler Technical Forum 13 10-22-2009 07:07 PM
Difference Between "Header Bikini/Safari and Bikini/Safari" JEEP97TJ TJ Wrangler Technical Forum 21 04-02-2007 07:57 AM
Broken Rear Shock BAR PIN "IDIEAS" smileyox TJ Wrangler Technical Forum 2 03-09-2007 02:43 PM
Gas tank "Tray" broken loose jeffwils YJ Wrangler Technical Forum 1 01-31-2005 08:46 AM
