what is the cheapest/easiest v8 swap?? - Page 2 - JeepForum.com
View Poll Results: im a newb but most ppl seem to run 302/350s
chevy 350 carbed 19 59.38%
ford 302 carbed 0 0%
chevy 350 fuel inj 6 18.75%
ford 302 efi? 7 21.88%
Voters: 32. You may not vote on this poll
post #16 of 23 Old 10-18-2013, 02:10 PM
SeanB95YJ
Originally Posted by superj View Post
Ford engine, ford trans, for tcase. Ford is driver side drop on 4x4 so axles won't need swapping
that is true... but re: GM transplants, full size GM trucks after 88 or 89 (whenever it is they went to IFS) also have the transfer case drop to the driver side. So don't let that be your sole decision maker
my NP241 drops in the right spot - I pulled it from a 93 or 94 Silverado 2500 pickup
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #17 of 23 Old 10-18-2013, 06:19 PM
SunDevilJeeper
Originally Posted by cryder44 View Post
I know you wanted cheap, but since none of the swaps are going to be cheap......Just put a Hemi in it and don't worry about the chevy and ford junk. lol
It's that exact same crap you're spewing right now that got me all jacked up. All I wanted was a Jeep to drive around and have fun in.
Now I'm over here shopping for a Dana 60 front and 14 bolt rear, 37s, coilovers, full roll cage, in the middle of a 5.2 magnum swap which might end up turning into a 6.1L Hemi instead, and a whole bunch of other crap.
This **** better be worth it, cause I'm getting anxious.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #18 of 23 Old 10-18-2013, 06:52 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by SunDevilJeeper
It's that exact same crap you're spewing right now that got me all jacked up. All I wanted was a Jeep to drive around and have fun in. Now I'm over here shopping for a Dana 60 front and 14 bolt rear, 37s, coilovers, full roll cage, in the middle of a 5.2 magnum swap which might end up turning into a 6.1L Hemi instead, and a whole bunch of other crap. This **** better be worth it, cause I'm getting anxious.
I'll be over to pick up your d30 soon then.
Michaelgoesrawr is offline
post #19 of 23 Old 10-18-2013, 09:17 PM
SunDevilJeeper
4.10s in it! You can have it, free of charge. The Jeep is out in Lucerne right now getting the welding done. Once that's all completed, it'll be back in my garage getting the V8 swap buttoned up and ready to go. Might do a couple donuts around the house, not sure yet. I'm thinking about a flat belly skid to go with it.
Once the axles are sitting in my garage and all prettied up, you're more than welcome to drop by and pick it up. That or if you want, we can swap the axle in garage in an afternoon?
You hittin that trail run with everybody tomorrow?
post #20 of 23 Old 02-28-2015, 03:55 PM
cryder44
Which V8 did you use Sundeviljeeper
What did you decide to go with on the v8 swap? Got any advice on the magnum and how you did it (if you did)?
Thanks
cryder44 is offline
post #21 of 23 Old 02-28-2015, 06:25 PM
SunDevilJeeper
Thanks
Magnum engines, for everything else, you're on your own.
http://www.jeepforum.com/forum/f12/5...e-yjs-1766593/
post #22 of 23 Old 02-28-2015, 07:12 PM
jsawduste
2006 YJ Wrangler
Thanks
I don`t think he is going to answer your question.
Last Activity 10-23-2012
jsawduste is offline
post #23 of 23 Old 02-28-2015, 10:05 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Great. Now this poll will never end.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
what's the easiest and cheapest engine swap in a yj? FASTMETAL YJ Wrangler Technical Forum 16 03-10-2014 05:42 PM
Easiest/Cheapest 1" Lift DaleII TJ Wrangler Technical Forum 13 01-07-2010 07:30 PM
Easiest and or cheapest upgrade from a BA/10 tmohler812 YJ Wrangler Technical Forum 6 08-05-2005 04:04 PM
Cheapest and Easiest Short Lift? NIUPonyBoy YJ Wrangler Technical Forum 9 08-09-2004 09:32 AM
easiest/cheapest way to run 35's ex-toyota YJ Wrangler Technical Forum 4 07-16-2004 11:46 AM
