What carb. is this? - JeepForum.com
post #1 of 4 Old 04-06-2013, 11:37 AM Thread Starter
jonji01
What carb. is this?
I believe this is a Rochester carb. It needs to be rebuilt. Can you help me identify it so that I can get a rebuild kit for it. Also, I am getting some deiseling when I shut the engine off. Could the type of carb be causing this? Should I rebuild this one or get a different one?
jonji01 is offline
post #2 of 4 Old 04-06-2013, 01:27 PM
pasinbuy
Is your fuel line kinked.
If dieseling is the problem try lowering the idle a bit to stop it. Also try moving the timing.
I can not help on what brand of carb it is, sorry.
pasinbuy is offline
post #3 of 4 Old 04-06-2013, 05:37 PM
lar308
rochester dualjet numbers are stamped on the side
lar308 is offline
post #4 of 4 Old 04-06-2013, 06:11 PM Thread Starter
jonji01
The line is kinked a little and needs to be replaced. This is a new to me Jeep that has been through 6 owners so now I'm trying to correct some of the issues it has. The idle is a little high Ill adjust it down a little.
Lar308 - thanks for the carb info.
jonji01 is offline
