what is the best yj rear axle swap ?? - JeepForum.com
post #1 of 38 Old 07-21-2009, 12:18 AM Thread Starter
Chaos_Theory_Z
ok so i have seen many mixed things on what to swap under a yj rear so i wanted to get every ones clear opinion. i want to know what is a good strong axle thats close width to a yj stock i know there are the explorer 8.8 ands the wagoneer 44s and maybe some others but wich do you think is better ?(i.e. easiness to install, strength, performance and availability wise )
Chaos_Theory_Z is offline
post #2 of 38 Old 07-21-2009, 12:35 AM
provinT13
It depends on what you're wanting to run. Lockers and 33's, an 8.8 or 44 would work fine. 8.8 worked good for me since I have a 2.5 and found one with matching 4.10's
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 38 Old 07-21-2009, 10:38 AM
USMC_JeepGuy
Rockwell 2 1/2 ton!
More specifics on your future plans would greatly increase the ideas people can throw at you.... Every application will be different to some degree.
USMC_JeepGuy is offline
post #4 of 38 Old 07-21-2009, 10:42 AM
UltimateCC
if your staying with 35s or under i would say a ford 8.8 is the easiest and cheapest
UltimateCC is offline
post #5 of 38 Old 07-21-2009, 11:46 AM
provinT13
^^ I can agree
post #6 of 38 Old 07-21-2009, 06:42 PM Thread Starter
Chaos_Theory_Z
ok so my plans are to runn 35 with a 4.5 Re lift and 1 inch body lift 4.88 gears , new brakes and doing it all within the next 2 months. i am going to keep the front cause i only wheel once or twice a month on light trails no rock crawling . so whats the best axle for that setup
post #7 of 38 Old 07-21-2009, 07:24 PM
speepdaedeesi
35s and under- 8.8
89 yj stock- sold
92 yj stock- sold
97 tj 2"bb,31" tires- sold
95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold
95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold
current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T
speepdaedeesi is offline
post #8 of 38 Old 07-21-2009, 07:41 PM
DriveTooMuch
1995-2001 explorer it looks like. Yes that is something I would like to have. How much is a fair price for one of these. This guy wrote up a pretty good page on it. http://www.jedi.com/obiwan/jeep/ford88.html
DriveTooMuch is offline
post #9 of 38 Old 07-21-2009, 08:16 PM
provinT13
Dana 44 for the front end.
post #10 of 38 Old 07-21-2009, 09:51 PM
foggybottombob
Two junkyards near me sell any rear axle complete for $100. Other yards go up to $300.
foggybottombob is offline
post #11 of 38 Old 07-21-2009, 10:28 PM
mario figueroa
I pay $350 for a 97 8.8 completed LSD 4:10 E brake lines,and so far so good.
mario figueroa is offline
post #12 of 38 Old 07-21-2009, 10:42 PM
DriveTooMuch
Well that's good to know the price can range a lot and deals can be found. I will start looking. Thanks.
post #13 of 38 Old 09-15-2010, 10:24 AM
Soldierfoley
Does an 8.8 front bolt right up to a yj? if so what do I ask for in the local scrapyard?
Soldierfoley is offline
post #14 of 38 Old 09-15-2010, 10:31 AM
Krochus
There's no such thing as a solid 8.8 front axle.
For the rear the exploder 8.8 has too much going for it for other axles to compete.
As to the front you already have one of the best axles ever put in a CJ/wrangler. Upgrade the axles to a one piece and you've got a front that's GTG up to the point where its time to bust out the 1 tons
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #15 of 38 Old 09-15-2010, 01:07 PM
Apollo12227
I've got a ford 9" installed in mine... Can't say that its cheaper or easier than the 8.8 lol. I went with it because it was unique (kind of)... And i've had years of experience with them. 8.8 disc brake brackets bolt right on to the ford 9" and having the ability to pull the 3rd member out is pretty sweet. This allows me to have a 4.56 setup with my detroit and a 4.56 setup with a full spool.
It's kind of a personal preference decision. The 8.8 is incredibly strong, affordable, and easy to swap. The d44 is a great swap as well as the ford 9"...
Pros Ford 8.8: Availability, price, disc brakes, ease of install, decent aftermarket, matching lug pattern
Cons Ford 8.8: Aftermarket not as good as ford 9" (but still strong enough), "everybody's doin it", c-clips (kinda)
Pros Dana 44: Probably alittle tougher than the 8.8 (debatable), maintaining chrysler (dana) parts, relatively unique.
Cons Dana 44: hard to find, no disc brakes, lower aftermarket support, pricy, hard to find
Pros Ford 9": Dana 60-like strength, removable 3rd member, easy gearing, HUGE aftermarket support, unique, easy disc brake conversion, matching lug pattern
Cons Ford 9": Cheap but hard to find, relatively pricy to build, relatively low pinion on carrier, much more involved to build.
Those are probably the easiest axles from my experience to swap into a jeep. Once you get on up the the Dana60 range then you would probably already be answering these questions yourself. naturally everything I just wrote is up for debate, I certainly don't claim one is better than the other and I dont claim to have covered everything in the above list... Again it is a matter of personal preference.
Good luck axle hunting!
Apollo12227 is offline
How to do a rear axle swap. Benderff TJ Wrangler Technical Forum 40 12-02-2012 04:53 PM
8.8 rear axle swap redjeep669 YJ Wrangler Technical Forum 8 05-07-2010 01:05 PM
89 XJ rear axle swap into 95 YJ? eatsleepjaydiem YJ Wrangler Technical Forum 4 05-03-2010 05:02 AM
rear axle swap lkg351 YJ Wrangler Technical Forum 6 02-24-2009 03:56 PM
Rear Axle Swap JSBlu974X4 TJ Wrangler Technical Forum 5 04-05-2004 09:02 AM
