what backspacing r u running???? - JeepForum.com
post #1 of 8 Old 05-19-2010, 07:59 PM Thread Starter
Balaban
I have a 88 YJ and Im putting on a 4" RC suspension lift and running 32" 11.50 15 Wrangler MTRs, what backspace r u guys running with 8" wheels or should I go with 10" wheels? And what bs on the 10s
Pics would be great, thanks
Balaban is offline
post #2 of 8 Old 05-19-2010, 08:23 PM
Champion
3.5" inches and still not enough in rear of jeep. i run 2" wheel spacers in rear too.
Champion is offline
post #3 of 8 Old 05-19-2010, 09:15 PM
yellow2kgt
You want 8" rims. I am running 4" back spacing and even with the narrower 8.8 I have plenty of clearance with my 32x 11.50s. Actually, I would have preferred a 4.5" backspacing to help keep the tires under the fender.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #4 of 8 Old 05-19-2010, 11:28 PM
MJMPC
4 inch BS with 31x10.50 on a 8 inch rim no prob.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 8 Old 05-20-2010, 12:39 AM
cubewhiz
4" BS with 33x12.50R15 on 15x8 rims. I had to put a couple of washers on one side to adjust my steering stop (only one side though), but other than that, it's great.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #6 of 8 Old 05-20-2010, 12:42 AM
hondacr21
hondacr21's Avatar
got 3.25" BS with 37x12.5 with rear 8.8 no issues at all
1995 Sahara, Borla header, Rear stretch 103" wheelbase, Sniper Fab Comp Corners with 3" flare, SOA with .75" SL, 2 1/2" Rancho lift on 37"s MTR's on 15x8 eagle alloys. JB4x4 steering bracket, M.O.R.E., 8.8 with limited slip and 4.10's, AA SYE, modified XJ front driveshaft, Superwinch EPi 9.0, homemade boatsides, 6 point cage.
hondacr21 is offline
post #7 of 8 Old 05-20-2010, 08:17 AM
jsahara24
33x12.50x15 on 8" rims with 4" of backspacing...they barely rub at full turn on the steering wheel...
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #8 of 8 Old 05-20-2010, 03:54 PM
cubewhiz
yeah, i was only rubbing when parallel parking. During normal driving, I never turned the wheel enough for it to cause rubbing.
cubewhiz is offline
Confused about backspacing and overall wheel size (What backspacing for a TJ?) uknowwho TJ Wrangler Technical Forum 21 10-03-2009 11:12 AM
Running Lights running all the time. Wolf92XJ TJ Wrangler Technical Forum 3 08-25-2008 10:37 AM
Running 33x12.50 on standard backspacing - Short Term msavard TJ Wrangler Technical Forum 6 12-19-2006 10:50 PM
Backspacing confederate2 TJ Wrangler Technical Forum 2 06-30-2004 01:17 PM
3.75 backspacing on a TJ JeepN2 TJ Wrangler Technical Forum 10 06-11-2004 02:51 AM
