What Auto Trans in 88 YJ 4.2 - JeepForum.com
post #1 of 3 Old 10-22-2007, 12:03 PM Thread Starter
Richo
Richo's Avatar
Is the TF999 the only automatic tranny that came in the 88 YJ with a 4.2? Thanks for the help!
1988 Black YJ with 258 and Auto
Richo is offline
post #2 of 3 Old 10-22-2007, 12:40 PM
bobbert350
bobbert350's Avatar
yup for your jeep yes
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #3 of 3 Old 10-22-2007, 04:09 PM
learfxr
A TH727 from a Waggy will work. That's what I have. Parted out a $600 Wagg and used the 727/NP208 and both axles. Sold the 360 V8 and other stuff and pretty much got my stuff free. Waggs can be found cheap, just make sure it's got the drivetrain you seek, or you may end up with a TH400 with a quadratrac and passenger side drop. The 727/208 combo is nice. Used a YJ front driveshaft that I shortened, the rear is a Wag that I shortened too. The only pain is the kickdown attachment. I spent the money on a Lokar kit for that. I used a B&M race shifter since it was cheaper, it's a pain in the butt cause of the rev lockout lever. Everyone says spend the money on an Art Carr shifter. The stock skid plate can be modded to mount the transmission, takes a little imagination and a welder helps.
89 YJ TBI350 TH350 203/300 Rocks and 43's in work
00 TJ 8.8 swap, 35's and 4.88's
learfxr is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
00 TJ Auto Trans ? white2000TJ TJ Wrangler Technical Forum 26 01-19-2010 10:59 AM
Can I tow 94 YJ with auto trans? cropduster YJ Wrangler Technical Forum 7 10-01-2007 09:38 PM
BL With An Auto Trans treehugger TJ Wrangler Technical Forum 11 01-08-2007 08:44 AM
auto trans BIGKURT666 TJ Wrangler Technical Forum 1 01-05-2007 09:02 AM
